Voltage readings
by haskill
Tags: readings, voltage
haskill
haskill is offline
#1
Apr3-07, 11:25 PM
P: 1
I am having trouble understanding this concept. I know that a voltmeter has an internal resistance of its own. When using a voltmeter to measure the voltage drop across a resistor, does the measurement shown on the voltmeter INCLUDE the voltage drop caused by the internal resistance of the voltmeter itself?
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
mjsd
mjsd is offline
#2
Apr3-07, 11:42 PM
HW Helper
mjsd's Avatar
P: 858
the voltmeter is insert in parallel with the load that you are trying to measure, as a result, the v drop across the internal resistance will be same as the drop across the load. the only different when compare to the case with no voltmeter is that the circuit will draw a different current...that's why you want it to be as large as possible so that this difference would be small..... since adding something in parallel changes the overall resistance. now, to measure voltage drop the voltmeter rely on a device called galvanometer (ie. a current reader) which is supposedly very sensitive to tiny current flow. since the internal resistance of a voltmeter is not infinite, some leakage current will flow through it, and therefore by carefully calibrating the current to voltage ratio, one can work out what is the voltage drop.
daniel_i_l
daniel_i_l is offline
#3
Apr4-07, 11:20 AM
PF Gold
daniel_i_l's Avatar
P: 867
The voltmeters resistance is assumed to be infinate relative to the resistor being measured - this way non of the current flows through it. But in reality it's still finate so there may be very small differences between the voltage measured and the actual voltage. Since this difference is close to constant it can be factored into the result.
Register to reply
Related Discussions
EEG Readings Biology 8
Recording Voltage readings in Excel Engineering Systems & Design 8
Best readings for me....plz help General Physics 0
Recommended E&M readings? Classical Physics 1
Suggested Readings? General Physics 6
