Prove or Disprove: if a | bc, then a|b or a|c
  • Thread starter Thread starter VinnyCee
The discussion revolves around the statement regarding divisibility: if \( a \) divides \( bc \), then \( a \) must divide either \( b \) or \( c \). Participants explore this claim using examples and reasoning related to positive integers.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants attempt to prove or disprove the statement through examples and reasoning. Some suggest using proof by contradiction, while others propose exploring specific values for \( a \), \( b \), and \( c \). Questions arise about the implications of prime factorization and the nature of divisibility.
There is active exploration of the claim with various examples being tested. Some participants express confusion about how to approach the proof, while others provide insights into the relevance of prime numbers. A participant has presented a case that appears to disprove the claim, leading to further discussion on the implications of the findings.
Participants are working within the constraints of a homework assignment that requires them to prove or disprove the divisibility statement. There is an emphasis on understanding the underlying principles rather than simply providing a solution.
VinnyCee
Prove or disprove that if a|bc, where a, b, and c are positive integers, then a|b or a|c.
Division! LOL...
Try a proof by contradiction.
Suppose that a|b and a|c are both NOT true. Then... what?
I really, really, really super suck at proofs.
Stop thinking about writing proofs. Just think about the statement. Write down a few examples, try to see what is happening.
Let's try a = 42, b = 3, c = 7.
[tex]\frac{a}{bc}\,=\,\frac{42}{21}\,=\,2\,\longrightarrow\,a|bc[/tex]
[tex]\frac{a}{b}\,=\,\frac{42}{3}\,=\,14\,\longrightarrow\,a|b[/tex]
[tex]\frac{a}{c}\,=\,\frac{42}{7}\,=\,6\,\longrightarrow\,a|c[/tex]
I don't think that there is a way to choose a, b and c such that a|b or a|c are not true. But how do I "show" such?
a is supposed to divide bc. How does 42 divide 21?
[tex]\frac{bc}{a}\,=\,\frac{21}{42}\,=\,0.5\,\longrightarrow\,a|bc\,not\,true[/tex]
[tex]\frac{b}{a}\,=\,\frac{3}{42}\,=\,0.071\,\longrightarrow\,a|b\,not\,true[/tex]
[tex]\frac{c}{a}\,=\,\frac{7}{42}\,=\,0.167\,\longrightarrow\,a|c\,not\,true[/tex]
Let's try different numbers...
a = 7, b = 3, c = 14, bc = 42
[tex]\frac{bc}{a}\,=\,\frac{42}{7}\,=\,6\,\longrightarrow\,a|bc\,is\,true[/tex]
[tex]\frac{b}{a}\,=\,\frac{3}{7}\,=\,0.428\,\longrightarrow\,a|b\,is\,NOT\,true[/tex]
[tex]\frac{c}{a}\,=\,\frac{14}{7}\,=\,2\,\longrightarrow\,a|c\,is\,true[/tex]
This only "shows" for these exact values of a, b, and c. How do I show for all a, b, and c?
So from one example you think it is true for all examples? try some more. if you just thnk about prime factorization, rather thatn actually putting numbers into a calculator, it becomes easy.
Prime factorization?
Dividing by two until the number is no longer divisible by two to get a prime at the end?
I don't see how that applies to this proof though.
Sigh.
Every number divides itself. What if a number is not prime?
A number is not prime when it can be divided by a number other than itself or one.
So 6, say, divides 6. 6 isn't prime, so how can you write 6 as the product of 2 smaller numbers?
3 * 2 = 6, yes, it is not prime.
How does this help with the proof though? I just don't understand how I am supposed to use prime numbers to prove anything about divisibility.
So 6 divides 2*3. Now, what does the question ask?
Prove or disprove:
if a divides bc then a divides b or b divides c.
Now do you see? And do you see why primes are important?
I still don't get it!
a = 6, b = 2, c = 3, bc = 6
[tex]\frac{bc}{a}\,=\,\frac{6}{6}\,=\,1[/tex] <----- claim holds
[tex]\frac{b}{a}\,=\,\frac{2}{6}\,=\,\frac{1}{3}[/tex] <----- claim does NOT hold
[tex]\frac{c}{a}\,=\,\frac{3}{6}\,=\,\frac{1}{2}[/tex] <----- claim does NOT hold
I guess using this case, the claim is disproved?
Good! You have disproved the claim. If you want some more insight into what's going on think about what would happen if the claim were a|bc AND a is prime implies a|b or a|c. Then would the conclusion hold?
  • · Replies 16 ·
  • · Replies 24 ·
