| Thread Closed |
Is there no energy conservation? |
Share Thread | Thread Tools |
| Apr6-07, 08:18 AM | #1 |
When we look at a particle's rest frame
its energy is Mc^2. But the particle decay has some width, so the products of the particle,generally, will have total energy different than Mc^2. How can it be, is there no energy conservation? |
| Apr6-07, 08:19 AM | #2 |
Mentor
Zz. |
| Apr6-07, 08:21 AM | #3 |
There certainly is conservation of energy, the two decay particles may have some non-zero velocity in the original particle's rest frame. Energy and momentum are always conserved (in a closed system).
Edit: Dammit Zz. |
| Apr6-07, 08:42 AM | #4 |
At the beginning the two decay product did not exist.
For instance when a rho particle decay into to pions, its energy in its rest frame is Mc^2. But the decay products, the two pions,generally will have different energy than the original rho. This is, as I understand, the meaning that the decay has a width. |
| Apr6-07, 09:02 AM | #5 |
The decay width is another name for the decay rate of a species. However, to answer what I believe your question to be; due to the HUP any particle with a finite lifetime has a non-zero mass distribution (has some uncertainty in the mass), this will result in a non-zero mass distribution for the products.
| Apr7-07, 06:53 AM | #6 |
What do you mean by some uncertainty in the mass, is this like uncertainty
of the momentum? Is the wave function of the particle is a superposition of eigen vectores with different mass eigen value? Isn't the mass of the particle is the exact value that appear in the hamiltonian? |
| Apr7-07, 07:00 AM | #7 |
Mentor
Zz. |
| Apr7-07, 07:35 AM | #8 |
First of all, I asked about the "mass width" because I don't understand this
expression. Second, the fact that "They measure a gazillion to get the statistics" is gust a technical mean to learn about the physics, it is still meaningful to ask about one particle. When I check about the muon mass in wikipedia or in any other place I always find gust one number, I never saw the width of its mass only of its decay, but even if there is such a thing as "mass width" it must influence the hamiltonian and also the one particle wave function. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Is there no energy conservation?
| conservation of momentum vs conservation of kinetic energy | Introductory Physics Homework | 18 | ||
| Simulatenous Conservation of Momentum and Conservation of Energy | Engineering Systems & Design | 9 | ||
| Conservation of energy or conservation of momentum | Introductory Physics Homework | 2 | ||
| Transformation of Kinetic and Gravitational Potential Energy:Conservation of Energy. | Introductory Physics Homework | 9 | ||
| Conservation of momentum (with conservation of energy) | Introductory Physics Homework | 1 | ||
