| Thread Closed |
parameter "k" with witch function sd[k]->minimum |
Share Thread | Thread Tools |
| Apr6-07, 03:40 PM | #1 |
Hi! I have to find the best parameter "k" with witch function sd[k]->minimum. I do that with FindMinimum. "sd" if a function that calculates the standard deviation from my experimental and model data. The model data is obtained from the mathematical model, first order differential equation...which I solve using NDsolve. The problem is that I cant make NDSolve work under FindMinimum.
Something like this: First, I define function that hace to solve the equation c'[t] == -k c[t], where "k" is a variable. This gives me model data later on. I define it as a function cause I dont know the value of "k" yet. Then I define another function which calculates the standard deviation: sd[k_]:= function(model data, experimental data) Still I have no concrete results. Then I use FindMiniumm for finding the "k" that gives the smallest Standard Deviation FindMinimum[sd[k], {k, 0.04}] And her is the problem, I cant make this combination to work .... help please? Many thanks! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: parameter "k" with witch function sd[k]->minimum
| optimization | Calculus & Beyond Homework | 9 | ||
| Optimization | Precalculus Mathematics Homework | 3 | ||
| optimization? | Calculus & Beyond Homework | 0 | ||
| Optimization | Introductory Physics Homework | 1 | ||
| OPtimization | Introductory Physics Homework | 1 | ||
