Solving a Complex Circle for $\theta$ Value
  • Thread starter Thread starter Mathman23
    Circle Complex
The discussion revolves around the equation \(|z| = \theta |z-1|\) in the context of complex numbers, specifically investigating the conditions under which this equation represents a circle. Participants explore various values of \(\theta\) and their implications on the geometric representation of the equation.
  • Participants examine the implications of setting \(\theta\) to different values, particularly zero and one, and how these affect the nature of the curve represented by the equation. There are attempts to rewrite the equation in standard forms and to interpret the geometric meaning of the conditions under which it ceases to represent a circle.
The conversation is ongoing, with participants providing insights and corrections to each other's interpretations. Some guidance has been offered regarding the standard forms of quadratic equations and their geometric implications, but there is no explicit consensus on the final interpretation of the conditions for \(\theta\).
There are indications of language barriers affecting understanding, as well as references to textbook definitions that may not align with the current discussion. Participants are also grappling with the definitions of circles and ellipses in the context of quadratic equations.
Mathman23
[tex]\{z \in \mathbb{C}| \mathrm{\theta} \in \mathbb{R}||z| = \theta \cdot |z-1|\}[/tex]
For which real-value of theta is the above no longer a circle?
If I choose theta to equal zero then I get [tex]|z| = 0[/tex], but doesn't that still make it a circle? But now the zero circle??
My second attempt:
[tex]\theta \cdot |z-1| \leq r[/tex]
where r is the radius of the circle.
Then I solve this with respect to theta and get
[tex]\theta \leq r \cdot |\frac{1}{z-1}|[/tex]
My third attempt:
since theta is a real number, then [tex]\theta \in [0, \infty \}[/tex]
[tex]|z| = \sum_{\theta = 0}^\infty (\theta \cdot |z-1|) = \mathop{\lim}\limits_{\theta \to t} \int_{0}^{t} \theta |z-1| d\theta = \frac{t^2 \cdot |z-1|}{2}[/tex]
I then insert into the the inequality [tex]|z| = \frac{t^2 \cdot |z-1|}{2} \leq r[/tex]
which can be solved with respect to t:
[tex]|t| \leq \pm \sqrt{\frac{2r}{|z-1|}}[/tex]
Could somebody here please be so kind to look at my attempteds solutions for this problem, and inform me if one or any of them are correct?
Then by inserting I get that [tex]|z| = \frac{(\sqrt{\frac{2r}{|z-1|}})^2 \cdot |z-1|}{2} = r[/tex]
Best regards
Fred
[itex]|z|= \theta |z-1|[/itex] can be interpreted as "set of all points whose distance from the orgin (|a|) is [itex]\theta[/itex] times its distance from 1 (|z-1|)". If [itex]\theta= 1[/itex] what is that set?
Another way to answer this is to "multiply it out": [itex]|z|^2= \theta^2 |z-1|^2[/itex]. If z= x+ iy then that becomes [itex]x^2+ y^2= \theta^2(x^2- 2x-1+ y^2)[/itex]. Write that quadratic in "standard form".
That is the complex unit circle with radius 1.
Standard form being spherical coordinants:
[itex](r \cdot cos(\phi))^2+ (r \cdot sin(\phi))^2= \theta^2((r \cdot cos(\phi))^2- 2(r \cdot cos(\phi))-1+ (r \cdot sin(\phi))^2)[/itex]
which inturn gives
[itex]r^2 = \theta^2 \cdot (r^2 -2r \cdot cos(\phi) -1)[/itex]
Do I then solve with respect to theta in order to obtain the right real-value?
Best Regards
Fred
Halls doesn't mean polar coordinates by 'standard form'. He means the standard form for a quadratic in two variables, ie (x-a)^2/A+(y-b)^2/B=1.
Excuse me; But English isn't my native language :)
So then I write the equation Hall wrote, and solve it with respect to theta ?
Best Regards
Fred
A quadratic written in this form (x-a)^2/A+(y-b)^2/B=1 represents a circle if A=B and A,B>0. Which value of theta will fail to give you such a form?
Hi
Then to represent a circle [tex]A=1=B=1[/tex], and [tex](1,1)>0[/tex].
Then in order for the original NOT to be a circle, then [itex]\theta \neq 1[/tex] isn't it?<br /> <br /> Best Regards<br /> Fred[/itex]
Mathman23 said:
Hi
[itex] <br /> Sorry, but completely backwards. You really need to review how to recognize what kind of curve (circle, ellipse, hyperbola) a quadratic equation represents. It's not that hard, but I think you've just forgotten. In the meantime, what happens to the quadratic part of the given equation if theta=1?[/itex]
Hello Dick and thank you for your reply:
I know of the equations of which you speak, and I have not forgot them. Its just then a textbook writes a equation in a certain way, it takes a bit long to understand the equation in its entirety.
The equation you present to me. Don't You mean the equation of the ellipse? Which according to an old textbook of mine is following:
((x-a)^2))/A^2 + ((x-b)^2)/B^2 = r, where (A,B)>0
Then if A and B both equal 1, then its a circle, but if (A,B) > 0, then it an ellipse. Then this must apply to my original problem too. That if theta equals 1, then its a circle, but if theta > 0 then its a ellipse of an unspecified size. That is what you referring too? Isn't??
Best Regards
Fred
If A and B both equal 1, it's a circle. If A and B are equal and nonzero, it's STILL a circle even if they are not equal 1. I don't know what an 'ellipse of infinite size' is - do you mean parabola? Maybe it's just language but I don't think you remember this stuff as well as you think you do. Once more, what is the quadratic like if theta equals one? Don't guess. Write it down.
Dick said:
If A and B both equal 1, it's a circle. If A and B are equal and nonzero, it's STILL a circle even if they are not equal 1. I don't know what an 'ellipse of infinite size' is - do you mean parabola? Maybe it's just language but I don't think you remember this stull as well as you think you do. Once more, what is the quadratic like if theta equals one? Don't guess. Write it down.
Once again taking
[itex]|z|^2 = {\theta}^2 \cdot |(x+iy)-1|^2[/itex]
this is the same as, (but I get a different right side, than Hall)
[itex]x^2 + y^2 = {\theta}^2(x^2 + y^2 - 2x + 1)[/itex]
which in sf gives:
[itex]x^2+y^2 = \theta^2 ((x-1)^2 + y^2 + 1)[/itex]
But then if theta = 1, then I get that the circle with a the zenter in (0,0) equals a circle with center in (1,0), but who has a negative radius. That cannot be right can it?
Mathman23 said:
Once again taking
[itex]|z|^2 = {\theta}^2 \cdot |z-1|^2[/itex]
which in sf gives:
Ok, you've corrected Halls. You are being careful. Now do two things. Put theta equal to 1 and tell me what kind of curve you get - then think about what happens if theta is not one.
If re-arrange it, then I get a straight line: 2x-2. How does that sound?
Best Regards
Fred
No, you get 2x-1=0. I thought you were being careful!? And makes sense. It's the set of points equidistant from (0,0) and (1,0). Now can you convince yourself for other values of theta you get a circle?
The set of points equidistant from two fixed points is a straight line! It is the perpendicular bisector of the line segment between the two points.
Why in the world would "standard form" for a 2 dimensional figure involve spherical coordinates?
I am sorry but are Y sure about the 2x-1 = 0.
Because I get ?
[tex]x^2 + y^2 - (x^2 -2x + 1) - y^2 -1 = 2x - 2 = 0.[/tex]
So basically I conclude here that if [tex]\theta = 1[/tex] then [tex]|z| = |z-1|[/tex]is not a circle. But If [tex]\theta > 1[/tex] then it return to be a circle!
I have a second follow up question which also deals with analysis.
Given [itex]\{z \in \mathbb{C}| e^{|iz|} \leq 1 \}[/itex],
Determ the set for the above:
By the Euler thereom then:
[tex]e^{|iz|} = |cos(z) + i sin(z)| \leq 1[/tex]
then if z = x+iy I get
[tex]e^{|iz|} = |cos(x+iy) + isin(x+iy)| \leq 1[/tex]
which inturn gives me
[tex]e^{-y} \leq 1[/tex]
But doesn't say nothing much about the set. Does it?
Best Regards
Fred
Where did you get the second '1' in your equation starting from this [itex]x^2+ y^2= \theta^2(x^2- 2x+1+ y^2)[/itex]??
No where you answer is correct. The extra "1" was dumb a** mistake on my part. Sorry :)
Best Regards
Fred
p.s. Regarding my second question. That I am able to reduce it e^-y <= 1.
Then "y" is the img-part of the number z = x+yi. Then the set to describe the equation e^{|iz|} <= 1, is that the set of all complex number on the form z = i?
On your second problem - there are so many things wrong here that it's hard to know where to start. Start from scratch and if you write something down give some justification for why you think it's true. Hint: |iz| is a real number. What kind?
Okay here is the question again in full:
Deduce the set
[tex]\{z \in \mathbb{C}|e^{|iz|} \leq 1 \}[/tex]
Solution:
Originally I thought that I needed to write out the above using Eulers formula, but since it doesn't make any difference. I choose not too.
Dick, You say that z should be scene as a real number. Then the z you are referring to must z = x+i0, there by where x belong to R. Isn't it?
Best Regards
Fred
Ok, start to deduce the set. What can you tell me about |iz|?
Now there is something funny happing if I tap in |iz| where z = x+iy. I get
[tex]|iz| = \sqrt{(x^2+y^2)}[/tex].
Doesn't this then mean, that express a circle with radius r and which has the center in (0,0)??
Best Regards
Fred
Best Regards
Fred
Yes, it would. So what can you tell me about r.
I can say that r is the real-valued expression of z.
Then to deduce the set, is it then
[tex]\{r = \sqrt{x^2+y^2}|x,y,r \in \mathbb{R}\}[/tex] ??
Best Regards
Fred
No. You've decided that exp(|iz|)=exp(r) where r=sqrt(x^2+y^2). How can that be less than or equal to 1?
Hi Dick,
If I choose (x,y) to be (0,0), exp(r) < = 1, is true. But then the final question. The set I am searching for, is that then [tex](0,0) \in \mathbb{R}[/tex]
Best Regards
Fred
Yes. It's only (0,0). But (0,0) is not in R, it represents 0+0i and it's technically in the complex plane! Do you see that clearly?
Therefore the sought set is: [tex]\{0+0i \in \mathbb{C}\}[/tex]. Isn't it?
Best Regards
Fred
That's it. Hopefully you are clear on all of the steps. It's really not that hard.
Hi Hall,
It was me being a dumb a**. Thank you for Your hints and answers.
Best Regards
Fred
