Ok, I think I know what I'm talking about this time! [:D]
Suppose we have div A = Q and curl A = H
Suppose V is a degree of freedom for A, so that:
div (A + V) = Q and curl (A + V) = H
the latter implies curl V = 0, and via Stokes' Theorem and the Fundamental Theorem, V = grad &phi for some scalar &phi. Therefore, any degree of freedom of the original equation must be the
gradient of a scalar field &phi.
If &phi is any solution to Laplace's equation, then
div grad &phi = 0 and curl grad &phi = 0
So the
degrees of freedom in the original equation is precisely the set of gradients of solutions to Laplace's equation.
As to the proof that any solution exists, I'm gonna cheat and say look at Wolfram for an explicit formula. [:D]
http://mathworld.wolfram.com/HelmholtzsTheorem.html
Ok I'm only gonna partially cheat.
If you're given that div V = Q and curl V = 0, then you can prove some V exists as follows:
Via Stokes' theorem, all contour integrals of V are zero, and thus line integrals of V are path independant, and the fundamental theorem for line integrals yields a scalar function &phi whose gradient is V.
So to solve the original equation, you just need to find a vector field W with curl W = H, and then apply the above reasoning to adust the divergence properly. For this part, I'm tempted to say that you simply apply green's theorem:
&int&int&int curl F dV = &int&int F * dA
integrated over a spherical ball/shell, and take the limit as the radius goes to 0, but I can't rigorously prove it off hand.
