Thread Closed
Change of integration order?
Share Thread Thread Tools
Apr13-07, 03:35 AM   #1
On this site,
http://www.math.ohio-state.edu/~gerl..._with_function
they changed integration order with e^(-ikt) integrated wrt t to t is now a constant and it's now integrated wrt k. How can one do this?
As stated from this sentence "By interchanging integration order and letting one has"
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Apr13-07, 03:55 AM   #2
[tex]f(x) \propto \int e^{ikx} \int e^{-ikt} f(t) dt dk = \int \int e^{ikx} e^{-ikt} f(t) dt dk = \int \int e^{ikx} e^{-ikt} f(t) dk dt [/tex]
There's nothing wrong with changing the order of integration here, think back of integrals as Riemann sums, changing the order in which you sum terms doesn't matter.
(You were going to integrate both exp(ikx) and exp(-ikt) over k anyway, so why not do that first and then integrate over t on which only the latter term depends).
Apr13-07, 05:22 AM   #3
Right, but why is the f (hat) function in terms of t?
f is in terms of x and k only.
Apr13-07, 05:49 AM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
k and t are "dummy" variables. They can call them whatever they wish!
Apr13-07, 06:10 AM   #5
So only x counts. This brings about the question, what is the point of the fourier transform.
Apr13-07, 08:02 AM   #6
The point?
Um, well, from my relatively limited experience in partial differential equations, in Fourier space differentiation and antidifferentiation break down into multiplication and division. Which is always good I suppose.
Apr13-07, 09:51 AM   #7
Recognitions:
Quote by pivoxa15 View Post
I'm not sure what you mean by that. Certainly in the integral you show, f is a function of x only. However, you have not said what it is you want to do with the Fourier Transform (the function inside the integral). Surely "the point of the Fourier transform" depends on that!
Apr13-07, 09:56 AM   #8
Take equation (234) from here and there, replace [tex]\hat{f}(k)[/tex] by equation (233).
Then you almost have equation (235), except that you have to change
the order of integration.
Quote by pivoxa15
Right, but why is the f(hat) function in terms of t?
The function [tex]\hat{f}(k)[/tex] is indeed a function of k, but it is not the function f, whose variable is x. Maybe you are a little confused about the meaning of [tex]\hat{f}(k)[/tex].
Think of the Fourier expansion as sort of linear combination of basis-vectors.
Let me try to explain:
Take the vectors in [tex]R^3[/tex].
Every vector can be represented as a linear combination of the basis-vectors [tex](1,0,0)[/tex], [tex](0,1,0)[/tex] and [tex](0,0,1)[/tex].
For example:
Take the vector [tex]v=(9,8,4)[/tex]. This vector can be written as a linear combination of the basisvectors vectors
[tex]u_1=(1,0,0)[/tex]
[tex]u_2=(0,1,0)[/tex]
[tex]u_3=(0,0,1)[/tex]
in the following way:
[tex](9,8,4) = 9 \cdot (1,0,0) + 8 \cdot (0,1,0) + 4 \cdot (0,0,1)[/tex]
[tex](9,8,4) = 9 \cdot u_1 + 8 \cdot u_2 + 4 \cdot u_3[/tex]
Let's call the numbers 9,8,4 in front of the basis-vectors coefficients.
[tex](9,8,4) = c_1 \cdot u_1 + c_2 \cdot u_2 + c_3 \cdot u_3[/tex]
where [tex]c_1 = 9[/tex], [tex]c_2=8[/tex] and [tex]c_3=4[/tex]
What if I choose different basis vectors, for example:
[tex]b_1=(3,0,0)[/tex]
[tex]b_2=(0,2,0)[/tex]
[tex]b_3=(0,0,2)[/tex]
Then our vector [tex]v=(9,8,4)[/tex] can be written as:
[tex](9,8,4) = 3 \cdot b_1 + 4 \cdot b_2 + 2 \cdot b_3[/tex]
Thus, the coefficients are 3,4,2 for our new basis-vectors
[tex]b_1[/tex],[tex]b_2[/tex] and [tex]b_3[/tex].
In general, you can write a vector [tex]v[/tex] as a linear combination of
basis-vectors [tex]b_k[/tex], where in front of the basis-vectors you have the coefficients [tex]c_k[/tex].
[tex]v = \sum_{k=1}^{3} c_k b_k[/tex]
In our last example we had
together with the coefficients:
[tex]c_1=3[/tex]
[tex]c_2=4[/tex]
[tex]c_3=2[/tex]
Just check the formula
by plugging in the above values:
[tex]v = c_1 \cdot b_1 + c_2 \cdot b_2 + c_3 \cdot b3[/tex]
[tex]v = 3 \cdot b_1 + 4 \cdot b_2 + 2 \cdot b_3[/tex]
[tex]=3 \cdot (3,0,0) + 4 \cdot (0,2,0) + 2 \cdot (0,0,2)[/tex]
So, every vector can be represented by some basis vectors [tex]b_k[/tex]
as
More general, if we have a vector with n entries instead of 3, we write
[tex]v = \sum_{k=1}^{n} c_k b_k = c_1 b_1 + c_2 b_2 + ... + c_n b_n [/tex]
Now, let's make a step from the discrete to the continuous case.
Say we have a function [tex]f(x)[/tex] and we also want to ask, whether it's possible to represent [tex]f(x)[/tex] as a linear combination of ''basis-vectors''.
Question: Is it possible to write
[tex]f(x) = \sum_{k=1}^n c_k b_k[/tex]
Let us be more specific and ask: Can I write [tex]f(x)[/tex] as a sum
of [tex]b_k = e^{ikx}[/tex]? So my new basis-vectors are [tex]b_k=e^{ikx}[/tex].
The question then becomes:
[tex]f(x) = \sum_{k=1}^n c_k e^{ikx}[/tex]
Indeed, it is possible, with a correction for the values of k.
Instead of going from k=1 to n, we use infinitely many basis-vectors, and
write [tex]k=- \infty[/tex] to [tex]k=+ \infty[/tex].
Corrected version:
[tex]f(x) = \sum_{k=-\infty}^{+\infty} c_k e^{ikx}[/tex]
The only question is, how do the coefficients
[tex]c_k[/tex] look like?
Have a look at Wikipedia
or here on page 2 of the pdf. It shows how the coefficients can be calculated.
To finally get to your Fourier integral, we replace the sum by an integral
[tex]f(x) = \int_{-\infty}^{+\infty} c(k) e^{ikx} dk[/tex]
Now, on your ohio-website, [tex]c(k)[/tex] is [tex]\hat{f}(k)[/tex], see equation (234) on the ohio-website.
Thus, [tex]\hat{f}(k)[/tex] plays the role of the coefficients.
Note 1 (on how to get from the Fourier series to the Fourier integral):
A Fourier series can sometimes be used to represent a function over an interval. If a function is defined over the entire real line, it may still have a Fourier series representation if it is periodic. If it is not periodic, then it cannot be represented by a Fourier series for all x. In such case we may still be able to represent the function in terms of sines and cosines, except that now the Fourier series becomes a Fourier integral.
The motivation comes from formally considering Fourier series for functions of period 2T and letting T tend to infinity.
The quote is taken from here.
Also see here
for the transition from the Fourier series to the Fourier integral.
Note 2: Summary:
In summary, consider the Fourier integral as a linear combination of basis vectors [tex]e^{ikx}[/tex] with the
coefficients [tex]c(k)[/tex] (or [tex]\hat{f}(k)[/tex]).
Note 3 (on applications of the Fourier transform:
Have a look at What is a Fourier Transform and what is it used for?.
Applications of Fourier Transform
in Communications, Astronomy, Geology and Optics
Note 4 (functions as basis-vectors?)
You might ask "Why can I consider the functions [tex]e^{ikx}[/tex] as
basis-vectors?"
The functions [tex]e^{ikx}[/tex] fulfill some properties similar to those of
basis vectors (1,0,0),(0,1,0),(0,0,1)from [tex]R^3[/tex].
The functions are orthonormal, that is they are
orthogonal to each other and they are normalized to 1 (delta-function?).
See
Fourier Analysis on page 3.
here on page 8.
Orthonormal functions: Definition on Wolfram mathworld
http://mathworld.wolfram.com/OrthonormalBasis.html
Note 5: Some examples of coefficients
Examples of Fourier transforms can be found here
Note 6: Java Applets
Approximation of a function by a Fourier transform
This applet shows you how you can approximate a function by a Fourier transform. The more
coefficients you use, the better the approximation becomes.
Applet: Rectangular pulse approximation by Fourier Transform
This applet shows how you approximate a rectangular shaped pulse. If you don't use enough
"basis-vectors" (bandwidth is limited), then the pulse will not look rectangular anymore. This has applications in
electronics where you want to transmit a signal but the bandwidth is limited.
Apr13-07, 06:09 PM   #9
I see. From all the Fourier transforms I have seen they use x as the integration variable in f (hat) which is confusing. f(hat) is not related to x in f(x) the original function but merely computes the coefficients of the basis vectors e^(ikx) for each k from -infinity to +infinity.
Apr13-07, 10:36 PM   #10
One thing I find fascinating is that there is a dirac delta function lurking inside every fourier transform.
Thread Closed
Thread Tools
Similar Threads for: Change of integration order?
Thread Forum Replies
Change of order integration Calculus & Beyond Homework 5
Change the order of Integrtation Calculus & Beyond Homework 7
Cycles per instruction question, why different CPI when I change for loop order? Engineering, Comp Sci, & Technology Homework 13
By changing the order would it change the answer? r-combinations Calculus & Beyond Homework 2
integration + change of order Calculus & Beyond Homework 1
