How Do You Solve Problems Involving Geometric Sequences and Series?
The discussion revolves around geometric sequences and series, specifically focusing on finding terms and sums within these mathematical constructs. Participants are exploring the relationships between terms and the application of formulas related to geometric sequences.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to find the first two terms of a geometric sequence given specific terms, questioning their understanding of the common ratio and the setup of the problems. Some participants express confusion about the sufficiency of information provided to deduce the sequence. Others discuss the formula for the sum of a geometric series and question the accuracy of their calculations.
The discussion is ongoing, with participants sharing their attempts and expressing confusion about the problems. Some guidance has been offered, but there is no explicit consensus on the correct approach or solutions. The conversation reflects a mix of interpretations and attempts to clarify the concepts involved.
Participants are working under the constraints of homework assignments, which may limit the information they can share or the methods they can use. There is a mention of a quiz context that may have contributed to the confusion regarding the material.
Astronomer107
I'm trying to get an A in honors AlgII/Trig and it is impossible, but I won't give up, so I have a few questions.
I'm not sure how to find the first two terms of a sequence (I got a few right, but most wrong and I don't know what's wrong). One of the problems is: a5 = 20; a8 = 4/25.
I set the problem up in this manner: 4/25 = -20r^3, but it does not turn out to be a perfect cube and the answer has no radicals in it, so it must work somehow.
Also: a1=2, a2=5, an=625/8, n=? I tried to find the common ratio, which I though was 2/5 (unless I forgot my basic algebra??), but it the whole problem is messed up.
Only one more thing, I promise! I'm pretty much altogether confused on geometric series. I was given the formula:
Sn= (a1-a1r^n)/1-r where r= common ratio and n is the number of terms in the series. One of the problems was: find the sum of the series: a1= 3/5, r=2, n-7. When I did this, it turned out to be a horrible number, when in fact the answer was supposed to be 47 and 5/8. If anyone could please just explain some of these things to me (I was making up a quiz while the teacher was explaining it). Thank you so much!
Is that the complete problem statement? If so, then I am as lost as you!
There has to be some rule in effect here, because there is no way to deduce the terms of a series from only two points. If you could state that rule, it would be helpful.
There's no way the answer is 47 5/8. There are only 7 terms, so I added them up with a calculator (erased it before writing it down, though :frown:).
Yo, d00d, my math skillz are fairly l33t, but I can't remember anything about geometric series, and can't find my big math textbook (all I could find was one that said that the infinite series x^k converges to 1/(1-x) if x < 1, and diverges otherwise .. not too useful)
But, if you can bust out with a more thorough description, I can probably help you out
a8=q*a7=q^2*a6=q^3*a5;
q^3=a8/a5=(4/25)/20=1/125;
q=1/5...
Mentor Edit: Rest of solution removed.[/color]
a1=2;a2=5;q=a2/a1=5/2;
an=625/8=a1*q^(n-1)=2*(5/2)^(n-1);
a1= 3/5; r=2; n=7
Sn= a1+a2+...+an;
Sn=a1+a1*r+a1*r^2+...+a1*r^(n-1); |*r
r*Sn= a1*r+a1*r^2+...+a1*r^(n-1)+a1*r^n; |-
Sn*(r-1)=a1*(r^n-1);
If you insert the numbers in and calculate, you will get 76.2.[/color]
Bogdan, I appreciate that you want to help, but please do not post complete solutions here. Astronomer 107 has to learn this stuff for herself.
Oops..sorry...that will never happen again...
