Can an Infinite Potential Barrier Conserve Energy in Real Life Scenarios?
The discussion revolves around the concept of an infinite potential barrier in quantum mechanics and its implications for energy and momentum conservation. Participants explore theoretical scenarios, question the existence of infinite barriers, and consider finite barriers as alternatives, while seeking real-life examples.
  • One participant questions how a particle with momentum p can pass through an infinite potential barrier while conserving energy and momentum.
  • Another participant argues that an infinite potential barrier would have a transmission probability of zero, suggesting that such a barrier cannot exist in reality.
  • Some participants propose that if the barrier is finite, momentum conservation could be possible, but this leads to confusion about the implications of the potential barrier's nature.
  • A later reply emphasizes that any change in momentum is due to the interaction with the potential barrier, comparing it to classical mechanics scenarios.
  • Participants express uncertainty about the conditions under which momentum can be conserved when transitioning between regions of different potential.
  • There is a suggestion that a delta function barrier might allow for some transmission, but this is not universally accepted.
  • One participant seeks clarification on real-life applications of these concepts, indicating a desire for practical examples.
Participants do not reach a consensus on the nature of infinite potential barriers or their implications for momentum conservation. Multiple competing views remain regarding the validity of infinite versus finite barriers and their effects on particle behavior.
Participants express confusion regarding the definitions and implications of infinite versus finite potential barriers, and the discussion highlights the dependence on specific scenarios and assumptions about particle interactions with potential fields.
This discussion may be of interest to students and enthusiasts of quantum mechanics, particularly those exploring the concepts of potential barriers, energy conservation, and their applications in real-life scenarios.
dakold
I got a question about an infinite potential barrier. If a particle with a momentum p travell through an infinite potential barrier, how can the energy be conserved, thus how can the particle have the same momentum after passing the barrier? Does there exists any real life example?
An infinitepotential barrier? If a barrier has infinite potential, the transmission probability is zero. Or to put it more precisely (since there really isn't any such thing as an infinite potential barrier), as the "height" of the barrier increases without limit, the transmission probability decreases asymptotically towards zero.
Can you give a specific example of the kind of situation you're thinking of?
I’m think of a particle, with momentum p, that travels in a region there the potential is zero and comes to a place there it exist an infinite potential barrier and travels through the region and comes to a region there the potential is again zero. How can the particle after the barrier have the same momentum p?
Off the top of my head, the ONLY "infinite" potential barrier that allows a transmission is a delta function barrier. All other infinite barrier with a finite width will cause the wavefunction to be identically zero at the boundary, so no transmission!
So, do you want to rephrase your question?
Zz.
Of course that can't be an infinite barrier. So the same particle as above, but the difference is that the potential is finite. How can the momentum be conserved?
OK, so now you are changing the scenario?
This is getting rather confusing.
Zz.
I understand that I have confused you. My thought was that I must have misunderstands something because of the explanations that stated above. The case that I did think of was an infinite potential barrier with a width, but if the wavefunction is zero at the boundary than the momentum can’t be conserved, or I’m a wrong? So if the momentum shall be conserved it most be a finite barrier, or?
If a particle, with momentum p, is traveling in a region with the potential is equal to zero, at some place the potential is not zero, if my thought above is correct than shall the potential be finite. After that the potential is again zero, is the momentum conserved?
You are wrong. You are forgetting that (i) this implies a reflection at the boundary and (ii) any change in momentum is due to the interaction with the potential barrier. This is no different than a classical ball-bounce-off-wall scenario!
Sure it is! This is because the potential field INTERACTS on the particle!
From the way you are describing this difficulty, you may want to go back and look at your classical mechanics again. I can reformulate everything you said here in terms of classical mechanics with a classical particle going into a potential field. Any change in momentum here can be entirely explained by the interaction of that particle with such a field. A comet from far away coming into the gravitational potential of a celestial body and changes its momentum. Do you see any problem in this case? That change is to be expected since it is interacting with an external field. You can easily say the same thing in the QM case.
Zz.
I understand how I can describe this in classic mechanic. So another question, where can I see this applicated in real life?
