How to get the normal bivector to a surface?
  • Context: Graduate
  • Thread starter Thread starter HolyPhia
    Normal Surface
The discussion focuses on constructing the normal bivector, or binormal, to a surface defined by the equation f(x)=0 in a D-dimensional Lorentzian manifold (M,g_{ab}). The normal vector is derived from the gradient {\partial}^{\mu}f, while the binormal is obtained using the Hodge dual of the volume element on the (D-2)-sphere. The final expression for the binormal is given as ω = (1/2) ω_{μν} dx^{μ} ∧ dx^{ν}, specifically for the coordinates t and r, indicating its relevance in contexts such as minimal surfaces and Frenet-Serret theory.
  • Understanding of differential geometry concepts, particularly manifolds.
  • Familiarity with the Hodge dual operation in differential forms.
  • Knowledge of the Frenet-Serret theory in E^3.
  • Basic principles of Riemannian geometry and metric determinants.
  • Study the construction of normal vectors in differential geometry.
  • Learn about the Hodge dual and its applications in differential forms.
  • Explore Frenet-Serret theory and its implications for curves and surfaces.
  • Investigate minimal surfaces in higher-dimensional Riemannian manifolds.
Mathematicians, physicists, and researchers in differential geometry, particularly those interested in the properties of surfaces in Riemannian and Lorentzian manifolds.
HolyPhia
How to get the normal bivector to a surface??
Given a surface [tex]f(x)=0[/tex] in a manifold, for examle [tex]R^n[/tex], its normal vector can be constructed as [tex]{\partial}^{\mu}f[/tex].
But i don't know how to construct the so-called normal bivector (or binormal) to this surface. It has the form as [tex]{\epsilon}_{\mu \nu}[/tex]...
You need to be more specific, I think. Is this in the context of Frenet-Serret theory in E^3? Or in say the context of minimal surfaces in E^4?
Thank you, i think I've got it.
For example, given a D-dimensional Lorentzian(or Riemann) manifold as [tex](M,g_{ab})[/tex] as
[tex]ds^2 = g_{tt}dt^2 + g_{rr}dr^2 + f(r)d{\Omega}^2_{D-2}[/tex],
then the hypersurface with constant t and r is a (D-2)-dimensional sphere. The point is that this sphere is of co-dimension 2. So its normal is a bivector.
We may get its binormal as follows:
First we choose the coordinates as [tex]\{ t,r,x^1,\cdots,x^{D-2} \}[/tex], in which [tex]\{x^1,\cdots,x^{D-2}\}[/tex] are coordinates on [tex]S^{D-2}[/tex]. Then we have the nature volume element on the (D-2)-sphere as
[tex]\tilde{\epsilon}=\frac{1}{(D-2)!}\sqrt{h}{\epsilon}_{a_1 \cdots a_{D-2}}dx^{a_1}\wedge \cdots \wedge dx^{a_{D-2}}[/tex].
Here h is the determinant of metric on the sphere.
Then we can use the standard "Hodge dual" to get the binormal as
[tex]*(\tilde{\epsilon}) = *\left( \frac{1}{(D-2)!}\sqrt{h}{\epsilon}_{a_1 \cdots a_{D-2}}dx^{a_1} \wedge \cdots \wedge dx^{a_{D-2}} \right)= \cdots = \frac{1}{2} {\omega}_{\mu \nu} dx^{\mu} \wedge dx^{\nu}[/tex]
For [tex]x^{a_1},\cdots,x^{a_{D-1}}[/tex] is limited on the sphere, so the non-zero component of the above equation is [tex]\mu,\nu = t,r[/tex].
Finally we can get a 2-form as
[tex]\omega \equiv \frac{1}{2} {\omega}_{\mu \nu}dx^{\mu} \wedge dx^{nu} \equiv {\omega}_{t r} dt \wedge dr[/tex].
This is just the so-called binormal to the sphere [tex]S^{D-2}[/tex]. Of course, some normalization may be made.
  • · Replies 17 ·
  • · Replies 0 ·
