Register to reply
End Correction
by vishmz@gmail.com
Tags: correction
Share this thread:
vishmz@gmail.com
#1
Apr19-07, 05:00 AM
P: n/a
In the analysis of sound waves generated in a pipe open at both ends
or open at one end only, the tube length is taken as L=L_0+0.3 D,
where L_0 is the actual tube length and D is the diameter of the tube.
Is this only a thumb rule? Or can a physical argument be given for the
factor 0.3 D? I havent found any argument in undergrad physics books.
Can someone help?
regards.
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
Gerard Westendorp
#2
Apr19-07, 05:00 AM
P: n/a
> Can someone help?
This is a low frequency approximation, that works quite well if the
wavelength is smaller than the pipe diameter.
At the open end of a pipe, you have velocity fluctuations but little
pressure fluctuations. So the impedance here is mass-like. The mass
impedance of a small slice (dx) of tube is jw rho dx/S. [w is angular
frequency, rho is density, S is cross sectional area, and j = the root
of -1.]
The mass impedance of the open end can be estimated by slicing up space
in concentric spherical slices of radius (r). Each slice has mass
impedance jw rho dr /(4 pi r^2). Integrate this over r from R (radius of
tube) to infinity, and you get jw rho /(4 pi R), the same as a tube
slice of length R/4, or D/8.
So the above estimate gives an end correction of 0.125 D. But it is a
bit crude, since we start integrating from a ball of radius R. In
reality, the pattern is more complex. If you account for the pattern in
more detail, you get a different value. I don't know if it is 0.3, I
thought it was higher.
Note that we used low frequency approximation, so that the whole field
around the tube rnd is behaving like a mass. It is a bit like an open
end has a little ball of air attached to it, whose mass has to be
displaced by the acoustic wave.
An important application of the end effect is the impedance of a small
hole. This is the same as a little pipe of length about 0.8D. You can
use this to design all kinds of resonators and dampers, and understand
how sound can leak through holes.
Gerard
vishmz@gmail.com
#3
Apr20-07, 05:00 AM
P: n/a
> > Can someone help?
> of -1.]
> Gerard
Dear Gerard,
Thanx for the explanation!!
Hans Werner Strube, strube&physik3*gwdg*de
#4
Apr21-07, 05:00 AM
P: n/a
End Correction
You mean "larger" rather than "smaller" - low frequency corresponds to
large wavelength.
Hans Werner Strube strube(@)physik3(.)gwdg(.)de
Drittes Physikalisches Institut, Univ. Goettingen
Friedrich-Hund-Platz 1, 37077 Goettingen, Germany
Register to reply
Related Discussions
Bolometric correction Astronomy & Astrophysics 4
QED correction terms General Physics 0
End correction? Introductory Physics Homework 0
End Correction Classical Physics 3
