| Thread Closed |
Ampere's Law |
Share Thread | Thread Tools |
| Apr19-07, 07:06 PM | #1 |
Ampere's Law
Calculate the magnitude of the magnetic field at a point midway between two long, parallel wires thar are 1.0 m apart and have currents of 10.0 A and 20.0 A, respectively, if the currents are: a) In opposite directions and b) in the same direction 2. Relevant equations B=kI/(2 pi X r) B is the magnetic field k is the proportionality constant... 4pi X 10^-7 and r is the radius 3. The attempt at a solution When it said that the currents move in opposite directions, i thought that the magnetic field at a point is B(net)= B(2) - B(1), and i got 4.0 X 10^-6 T. When it said that the currents move in the same direction, i did B(net)= B(2) + B(1), and i ended up getting 1.2 X 10^-5 T. But the answer at the back of the book is the opposite, the answer that i got for a turns out to be the answer for b and vice versa... are my equations wrong? |
| Apr19-07, 07:21 PM | #2 |
in fact , you are wrong in directions. try use you right hand to sure when to add or minus
| Apr19-07, 07:26 PM | #3 |
so you calculation must be all right , conside more about it: |
| Apr19-07, 07:37 PM | #4 |
Ampere's Law
you must distinguish between the diretions of currents and magnetic field .
remember the magnetic field is vector field,its directions has complicated relation with the currents. does that help, my pretty baby? |
| Apr19-07, 08:03 PM | #5 |
thank you very much enricfemi! :D
| Thread Closed |
| Thread Tools | |
Similar Threads for: Ampere's Law
| ampere's law | Introductory Physics Homework | 1 | ||
| Ampere's Law | Classical Physics | 1 | ||
| Ampere's Law | Introductory Physics Homework | 2 | ||
| ampere's law | Advanced Physics Homework | 2 | ||
| Ampere's law | Introductory Physics Homework | 2 | ||
