Kinetic energy of space probe problem
The kinetic energy required for a 10-kg space probe to be launched from Planet Zero, with a mass of 4.0 x 1023 kg and a radius of 2.0 x 106 m, to reach a maximum distance of 4.0 x 106 m from the center is derived from the difference in gravitational potential energy between two configurations. The initial potential energy is calculated using the formula U = (GMm/radius), while the mechanical energy at the maximum distance is E = - (GMm/2d). Accurate calculations and attention to signs are crucial for determining the correct kinetic energy value.
  • Understanding of gravitational potential energy (U = GMm/r)
  • Knowledge of mechanical energy concepts
  • Familiarity with the gravitational constant (G)
  • Basic algebra for solving equations
  • Calculate gravitational potential energy for different planetary bodies
  • Explore the concept of mechanical energy conservation in space missions
  • Learn about the gravitational constant (G) and its applications
  • Study the effects of distance on gravitational forces and energy
Students in physics, aerospace engineers, and anyone interested in space probe dynamics and gravitational energy calculations.
chouZ
Planet Zero has a mass of 4.0*10^23 kg and a radius of 2.0*10^6 m . With what kinetic energy should a 10-kg space probe be launched vertically from the surface of Zero so as to achieve a maximum distance of 4.0*10^6 m from Zero's center?
I found the initial potential Energy, U=(GMm/radius planet Zero) and then the mecahnical energy at the end, E= - (GMm/2d)
its not right..HELP!
I think most likely you are not using the right values for the distance.
The question is effective asking for the difference in gravitational potential of two configurations, and they are:
1. The space probe on the surface of this planet (distance of 2.0x10^6 from center)
2. The space probe at a distance off the surface (distance of 4.0x10^6 from the center)
Try doing the calculations carefully again.
How do you know it isn't right? What did you get for your final value? Be careful of your signs.
