Solving the Mystery of AlCl3 & NaOH/NH4OH Precipitation
The discussion centers on the precipitation reactions of aluminum chloride (AlCl3) with sodium hydroxide (NaOH) and ammonium hydroxide (NH4OH). When NaOH is added to AlCl3, the precipitate Al(OH)3 dissolves due to the formation of the aluminate ion (Al(OH)4-), while the precipitate remains in the case of NH4OH because it does not complex with Al(OH)3. The experiment involves using 5 mL of 3 M aluminum chloride and 2.5 mL of both 3 M sodium and ammonium hydroxide solutions. The key takeaway is the difference in complexation abilities of NaOH and NH4OH with Al(OH)3.
  • Understanding of precipitation reactions in chemistry
  • Familiarity with molarity and solution preparation
  • Knowledge of complex ions and their formation
  • Basic chemical equation writing and balancing
  • Study the formation and properties of complex ions in aqueous solutions
  • Learn about the solubility rules and their applications in precipitation reactions
  • Research the practical applications of aluminum hydroxide in various industries
  • Explore the differences between strong and weak bases in chemical reactions
This discussion is beneficial for high school chemistry students, educators, and anyone interested in understanding precipitation reactions and complex ion formation in inorganic chemistry.
ChemDunce
Hey Chem geniuses!
I am a struggling high school chem student who couldn't combine water with water without blowing something up so some help would definitley be appreciated.
My chem final has been issued already and it is as follows:
Put 5 mL of 3 M aluminum chloride solution in each of two test tubes. To one test tube add a few drops of 3 M sodium hydroxide solution. Then add more sodium hydroxide solution, with stirring, until the precipitate dissolves. Treat the other test tube similarly, but use 3 M ammonum hydroxide solution to obtain precipitation and then add more ammonium hydroxide solution. Why did the precipitate dissolve in one case and not the other?
I calculated the amounted needed to be 2.00 grams of aluminum chloride. Since I need to put that amount in TWO test tubes, I requested 4.00 grams for my experiment. The 3M of Sodium Hydroxide and 3 M of Ammonium Hydroxide were requested in 2.5 mL each. If anyone sees error in this, please let me know! Thanks :smile:
The question remains... why did one case precipitate and not in the other? :confused:
Thanks a bunch.
complexing ions...
Hi ChemDunce,
The reason that the precipitate dissolves in one of the solutions is because the equilibrium moves to the right until Al(OH)3(s) is precipitated; this easily reacts with excess NaOH to give the aluminate ion, Al(OH)4-(aq). Basically, the Al(OH)3 is complexed to create an ion that dissolves in solution.
The ammonium hydroxide solution is unable to complex the Al(OH)3 precipitate and, therefore, remains as a precipitate. Hope this information helps. Good luck on your final!
Fernando
Thanks a bunch! Now, for the chemical equations, the AlCl3+ NH4OH is not a double replacement, then what would it be? While the AlCl3+NaOH ---> Al(OH)4-?
Are there any practical uses for this reaction in everyday life?
  • · Replies 20 ·
11K
