| Thread Closed |
Toward a Common Solution to the GR + QFT & "Wave function collapse"Problems |
Share Thread |
| Apr28-07, 05:00 AM | #1 |
Uncle Al wrote:
> GR (c=c, G=G, h=0) cannot be unified with quantum field theory (c=c, > G=0, h=h). It can. The results are surprising in several respects. First, though it is not well-known, it's actually possible to do Hamiltonian dynamics without splitting spacetime into space+time. This was always one of the main obstacles to incorporating a field theory that truly respected the spirit of relativity. However, there are substantial differences. The covariant Hamiltonian increases the velocities and momenta componets 4-fold, pulling a full Legendre transform H = sum (p^m dq/dx^m) - L. The Poisson bracket structure has to be modified. You don't have a nice [p,q] relation anymore, but rather, something involving differential forms [sum p^m dS_m, q], where dS_m is the (n-1) surface element orthogonal to coordinate axis x^m. How quantum theory generalizes in terms of the covariant Hamiltonian isn't yet fully known, but this is the foundation ultimately of the resolution between how quantum theory and General Relativity handle time. The fix, to put it simply, is on the quantum side, fixing the way it approaches quantization through modification of its Hamiltonian foundation. Second, there are clear-cut issues that come about as a result of trying to quantize gravity; these show up some novel principles. They lead directly to the notion of hybrid classico-quantum theories (i.e. quantum theories with superselection). The metric is represented by the vierbein frame field. This field determines, locally, which frames are inertial. A fluctuation in this field leads to a fluctuation in which frames are inertial. A superpositoin of two states with slightly different metrics results in a superposition of two vacuua that disagree slightly one which frames are inertial. One sees the others' frames as accelerating. As is well-known from the Unruh-Davies effect, an accelerating vacuum does not reside in the same sector as the inertial vacuum. They cannot coherently superpose! They can only participate in incoherent superpositions. Thus, superselection enters directly into the core of quantum theory. The fluctuation of the vierbein field leads to an effective mean time to superselection or (as Penrose put it, as mean time to "objective wavefunction reduction"). Penrose's "objective reduction" is just a fancy way of saying "gravitationally induced superselection". Thus, the vierbein field can no more be quantized as a bona fide quantum field, than phonons in a solid can be. They enter the picture as quasi-particle modes. This not only buttresses the conclusion Jacobson posed in his 1995 paper, but fall right into the came of Sardanashvily's "gauge gravitation" formalism .. which also brings us full circle, since this formulation is set squarely in the language of the covariant Hamiltonian approach. Sardanashvily adds in an extra point that had been little noted. The vierbein is associated with the fermion field. It is the affine part of the gauge field, while the connection coefficients are the spin or curvature part. However, the fermion field does not transform under the full local GL(4) symmetry group of the manifold. It selects out an inertial frame -- namely, the vierbein field itself. It only transforms locally under SO(3,1). The broken symmetry GL(4) -> SO(3,1) yields 10 Higgs-like modes that are none other than the 10 components of the metric. These parametrize between the different vacuum sectors. Each sector being a separate state-space that cannot coherently superpose with the states of any other sector. In other words, the vierbein field is essentially classical and can only be quantized as quasi-particle modes. In the process of uncovering this revelation one also sees a golden path laid out to one of the major issues of quantum theory: how do coherent superpositions undergo the effective "superselection" associated with measurements, aka "wave function collapses"? How is playing the role of the handmaiden of all superselection? The answer is the vierbein. This consequently leads to what Sardanashvily calls the "fermion complex" Each separate "setting" of the vierbein defines a subset of possible fermion fields that reside in the sector associated with the field. But different vierbeins give you different sets, and the fermion fields that reside in different sectors cannot superpose coherently. One way this may enter quantum field theory is directly into S-matrix theory. There may be a superselection on particle number between Feynman different diagrams that have different external legs. I'm not entirely sure, but I think that it's a hidden or tacit assumption already made when carrying out actual calculations to treat the different "tree sectors" of the Feynman diagrams as residing in different sectors. |
| Thread Closed |
Similar discussions for: Toward a Common Solution to the GR + QFT & "Wave function collapse"Problems
| electron two slit experiment with gradual "collapse"? | Quantum Physics | 5 | ||
| Photon "Wave Collapse" Experiment (AJP Sep 2004, Thorn et al.) | General Physics | 5 | ||
| how fast does the wave function "decollapse"? | Quantum Physics | 21 | ||
| Photon "Wave Collapse" Experiment (Yeah sure; AJP Sep 2004, Thorn...) | Quantum Physics | 128 | ||
| Help with one of those "how much solution to equal a percentage of acid" problems! | Introductory Physics Homework | 1 | ||
