Can Ethanol in Vodka Affect the Effectiveness of Antibiotics on Bacteria?
  • Thread starter Thread starter jimmy p
    Alcohol
The discussion centers on the effects of ethanol, specifically in vodka, on the effectiveness of antibiotics against bacteria. Participants explore the interaction between alcohol and various antibiotics, the experimental setup involving bacterial cultures, and the implications of ethanol concentration on bacterial viability.
  • Experimental/applied
  • One participant notes that only a few antibiotics are affected by alcohol, though they do not recall specific examples.
  • Another participant discusses disulfiram-like reactions associated with certain antibiotics, particularly metronidazole, and mentions the risks for chronic alcohol users.
  • A participant suggests that ethanol may not directly affect the antibiotic but rather the body's metabolism of it, questioning the validity of the experimental approach if ethanol kills the bacteria.
  • There is a suggestion to use a disc assay instead of mixing alcohol directly with agar, with a note that low concentrations of alcohol might not significantly impact bacterial viability.
  • Concerns are raised about using high concentrations of alcohol, as it could lead to bacterial death, thus skewing results.
Participants express differing views on the impact of ethanol on antibiotic effectiveness, with some suggesting that ethanol primarily affects metabolism rather than the antibiotics themselves. There is no consensus on the best experimental approach or the implications of ethanol concentration.
Participants highlight limitations in the experimental design, particularly regarding the concentration of ethanol used and its potential to kill bacteria, which may confound results. There are also unresolved questions about the specific antibiotics affected by alcohol.
This discussion may be of interest to researchers studying antibiotic interactions, microbiologists conducting experiments with bacterial cultures, and individuals exploring the effects of alcohol on drug metabolism.
jimmy p
I have been trying to help a friend out. She is researching how Antibiotics are affected by alcohol... well ethanol (she is using vodka on her different strains of bacteria). Unfortunately we can only find how drugs like cocaine affect antibiotics. Can anyone suggest any links or have any info on this?
Biology news on Phys.org
From my understanding, there are only a few antibiotics that are effected by alcohol. Don't rember off the top of my head, where I read that but I will think about it.
Nautica
The one that springs to mind right away are the disulfiram-like reaction has been linked with a number of anti-infectives and can cause significant morbidity...(tachycardia, facial flushing, hypo or hypertension etc.). The reaction is classically associated with metronidazole but is also well documented with certain cephalosporins and isolated cases reporst with chloramphenicol.Chronic alcohol abusers appear to be at greatest risk.
Remember, we use Disulfiram to deter further ingestion of alcohol, by inhibition of the enzyme aldehyde dehydrogenase, causing a build-up of acetaldehyde, a toxic by-product of ethanol metabolism By the same mechanism, other compounds have been linked with disulfiram-like reactions, and antibiotics are no exception. In general, these reactions are rare and occur spontaneously. Although all patients should be counseled and warned of this potential interaction, it appears that patients who chronically consume large amounts of alcohol may be at higher risk for developing these reactions because they may have a greater accumulation of acetaldehyde. The likelihood of a reaction exists while the drug is still present in the body, and reactions have occurred -- even with minimal amounts of alcohol -- up to a day after the last dose of an antibiotic. Thus, in general, it is recommended that patients abstain from alcohol during, and for 2 to 3 days after, therapy with any agents implicated in causing disulfiram-like reactions.
Also, depending on the antibiotic, I'm sure the alcohol affects the induction or degradation pathway system in the liver.
Is she using animals infected with bacteria or bacterial cultures in dishes? You're not going to learn much about the effectiveness of antibiotics if you start out by applying ethanol to your bacteria...usually the ethanol itself will kill the bacteria. My understanding is that the ethanol doesn't directly affect the antibiotic, it affects the way the body metabolizes the antibiotic...but I could be wrong on that.
She is mixing the alcohol in with an agar jelly and then applying the bacteria. Hmm that could explain some results...
why don't she used disc assay instead of mixing the alcohol directly the agar. Anyway low concentratrion (1-10%) of alcohol migth not have such an effect on the bacteria. If she is using 75% alcohol then the bacteria are going to die. She should use the concentration that can be found in the blood (0 mg to 300 mg per 100 ml).
  • · Replies 18 ·
