What is the Maximum Energy of a Photon in Positron-Electron Annihilation?
The problem involves a positron colliding with a stationary electron, leading to their annihilation and the production of two photons. The inquiry focuses on determining the maximum possible energy of one of the photons generated in this process, within the context of relativistic physics.
  • Participants discuss the use of 4-momentum vectors and the center of mass (CM) frame as potential tools for analysis. There is mention of calculating energy in different frames and the implications of momentum conservation. Questions arise regarding the conditions under which photon energy is maximized and the relationship between different reference frames.
The discussion is ongoing, with participants exploring various frames of reference and questioning the assumptions about maximum photon energy. Some guidance has been provided regarding the use of the rest frame for calculations, and there is an acknowledgment of the complexities introduced by relativistic effects such as Doppler shifts.
Participants express uncertainty about the physical conditions that lead to maximum photon energy and the implications of frame dependence in relativistic scenarios. There is a focus on ensuring clarity around the assumptions made in different reference frames.
tnho
A positron having a kinetic energy equal to its rest mass energy mec^2 collides with a stationary electron. The positron and the electron annihilate in the process and two photons are created. What is the maximum possible energy of a photon produced in the annihilation process??
4-momentum vectors(??)
CM frame can help ??
4-momentum vectors, absolutely. Though it's hard to be sure until you write some down and try them out. CM may help (at least to think about) but I suggest you try first in the rest frame of the electron since it seems that is the frame in which they want an answer.
I'll definitely get a boost to the CM frame so that the two final photons travel at opposite direction.
then look at momentum 4 vectors of each objects, take the 4 vector dot product. and you'll get something involving the usual dot product of the two momentum vector (of the photons). simplify things (put everything in terms of energy of the two photons, E1, E2) (the dot products can be simplified since the photons travel at opposite direction). then work some inequality out (complete the squares, work out AM-GM or Cauchy if you know those).
formulas to use:
recall:
[tex]E=pc=hf[/tex] for photons
and the CM frame moves at:
[tex]\vec{V}_{\text{CM}}=\frac{\sum_i{\vec{p}_ic^2}}{\sum_i E_i}[/tex]
in fact, i don't know under what physical conditions, the energy of photon is at its maximum.
If the energy of photon is maximum in one frame (says CM frame), it is also maximum in another frame (says Rest frame), isn't it??
Thx
Thx
Not true at all. This why I suggested you stay in the rest frame. There is such a thing as a doppler shift.
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 23 ·
