Calculating Maximum Height of a Child Swinging from a Rope
The discussion revolves around a physics problem involving a child swinging from a rope, specifically focusing on calculating the maximum height reached by the child based on their initial speed and mass. The subject area includes concepts of energy conservation and kinematics.
  • The original poster attempts to apply the conservation of energy principle to find the maximum height and expresses confusion regarding the second part of the problem, questioning how different masses can achieve the same height with varying speeds.
Some participants have provided insights into the problem, noting that mass does not affect the outcome in this context, which may help clarify the original poster's confusion. However, the discussion includes varied interpretations and does not reach a consensus.
The original poster expresses urgency in seeking help, indicating a time constraint for resolving the problem. There is also a note about the age of the question being discussed, which some participants question.
kassy_in_the_sky
Several children, pretending they are playing in the jungle, suspend a rope from an overhead tree limb. A child of mass 40 kg running at 8.0m/s grabs the rope and swings off the level ground.
a) What maximum height does the child reach?
b) How fast would a 30 kg child have to run to reach the same height as the 40 kg child?
½mv1²+mgh1 = ½mv2²+mgh2
a) m=40kg, v1=8.0m/s, h1=0m, g=9.8m/s², v2=0m/s (at max height v=0)
h2=?
½mv1²= mgh2
h2 = 3.27m = 3m (is this correct?)
im really confused with B... coz i got 8m/s... it doesn't make sense to me how they can run at the same speed and achieve the same height??!
this is really urgent... so please help me! >_< thanks!
Notice that the mass drops out of the equations entirely. So the mass has no significance to the problem.
Intuitively, if you increase the mass, the person has greater kinetic energy when he starts. But getting to the same height also requires more energy. It works out that the increases in energy are identical.
cookiemonster
thanks! ^^
I believe that:
1. The initial inertial velocity is a convention between the different reference frames.
2. The total tensional energy of an isolated system is equal to zero.
3. The total energy of an isolated system is equal to zero.
Antonio A. Blatter
Unfortunately, you're responding to a question that's about 4 years old.
Zz.
Zz.
Hmm, why is that frowned upon? I mean, physics problems are timeless afterall :)
  • · Replies 19 ·
