How Can I Build a Steering Mechanism for a Toy Car with a 3-Wire Remote Control?
  • Thread starter Thread starter amilabanuka
    Car Steering
This discussion focuses on building a steering mechanism for a toy car controlled by a 3-wire remote control. Key components include a motor attached to a gearbox for enhanced torque, and various steering mechanisms such as spring-loaded systems, teardrop gears with rubber band slippage, and spiral gears without springs. The control system utilizes a split supply and DPDT (Double Pole Double Throw) spring return to center switches, which are wired in an X configuration to change polarity for steering direction.
  • Understanding of basic electronics and wiring principles
  • Familiarity with motor control systems
  • Knowledge of gear mechanisms and their applications
  • Experience with DPDT switch configurations
  • Research motor gearbox options for increased torque in toy applications
  • Explore different steering mechanisms, focusing on spring-loaded and gear-based designs
  • Learn about wiring configurations for DPDT switches in remote control systems
  • Investigate the principles of polarity switching in electric motors
This discussion is beneficial for hobbyists, engineering students, and anyone interested in building remote-controlled vehicles, particularly those seeking to understand steering mechanisms and control wiring.
amilabanuka
Hi guys.
i need help to make a steering mechanism for a toy car.
the car should be able to drive forward and reverse and can be turned. car should be controlled by a wired remote control with maximum of 3 wires.
this seems to easy, but I'm still in the first year and do not have knoledge about these stuffs.
my main problem is how to make a steering mechanism and how to manage control with 3 wires.
buy a motor attached to a gearbox for extra torque, one way is spring loaded to return to center with a flat toothed bar, next is a teardrop gear with rubber band slippage, next would be a spiral gear with no springs. as far as the wires go you'd have to have a split supply and use dpdt spring return to center switches wired with the outer poles forming an x to change polarity.
9K
  • · Replies 17 ·
  • · Replies 22 ·
11K
