How Does Orientation Direction Affect Stokes' Theorem Calculations?
The discussion centers on the implications of orientation direction in Stokes' Theorem calculations, specifically regarding a vector field F = and a surface S defined by the cone y^2 = x^2 + z^2 between y = 0 and y = 3. The correct orientation, as clarified, is towards the positive y-axis, which necessitates a clockwise (CW) traversal around the boundary of the surface. This orientation ensures that the unit normal vector points in the positive y direction, aligning with the requirements of Stokes' Theorem.
  • Understanding of Stokes' Theorem and its applications
  • Familiarity with vector calculus and surface integrals
  • Knowledge of parametric equations for surfaces
  • Concept of orientation in vector fields and surfaces
  • Study the implications of orientation in Stokes' Theorem with various vector fields
  • Learn how to compute surface integrals using different parameterizations
  • Explore the relationship between clockwise (CW) and counterclockwise (CCW) orientations in vector calculus
  • Investigate examples of Stokes' Theorem applications in physics and engineering
Students and professionals in mathematics, physics, and engineering who are working with vector calculus, particularly those focusing on Stokes' Theorem and surface integrals.
jesuslovesu
F = <x^2 y^3 z, sin(xyz), xyz>
S is part of the cone y^2 = x^2 + z^2 that lies between y = 0 and y = 3.
Oriented in the direction of the positive y-axis.
I know how to do the integral, and I get the correct answer except it's the negative of the answer. My question is, what direction does "oriented in the direction of the positive y-axis" imply? I thought it was CCW, but if I do that, I get the opposite of the answer.
I am using
x = 3cos(t)
y = 3
z = 3sin(t)
My books uses
x = 3sin(t)
y = 3
z = 3cos(t)
But I'm not sure why they would use that, unless the direction of the curve is CW...
What does CCW vs. CW really mean? Imagine we have
z axis
----------x axis
and the positive y-axis going into the plane. So our cross section is going to be a circle at each point of y. Oriented in the direction of the positive y-axis means the unit normal should be pointing in the positive y direction, note in this case that means it's inside the cone. So on the rim, it should travel s.t. on the inside of the cone, the surface is to your left. So your head (if you were walking around the boundary), would be pointing towards the y-axis in this case. The surface is to your left, so if you can imagine it, you would be (if standing so z=y, x=0) upside down in the picture above (if everything was drawn in). Thus, you would be looking to what we call the right, and would actually travel clockwise in this case
Thank you, it was driving me nuts, now i understand
