david90
- 311
- 2
how many amp/hour can a small 1.5v produce? If u link 6 together to form a 9v, would the amp/hour change or only the voltage?
The discussion centers on the amp-hour capacity of 1.5V batteries, particularly NiMH batteries, which typically provide around 1.7 amp-hours. When six 1.5V NiMH batteries are linked in series, they produce a total voltage of 9V while maintaining an amp-hour capacity of 1.7. Conversely, connecting six batteries in parallel results in a voltage of 1.5V but increases the total amp-hour capacity to 10.2, although the actual voltage of NiMH batteries is closer to 1.2V.
PREREQUISITESElectronics enthusiasts, battery engineers, and anyone involved in designing or optimizing battery-powered devices.
It very directly depends on how small. You absolutely MUST specify this in order to get an answer. Just consider this quote by russ:david90 said:how many amp/hour can a small 1.5v produce?
russ_watters said:... NiMh batteries get about 1.7 amp-hour.
... linking 6 in parallel gives you 10.2 amp-hour at 1.5v (actually, NiMh are more like 1.2v).
