Radioactive isotopes please read
The discussion centers around the use of radioactive and stable isotopes in biochemical research, particularly how these isotopes help scientists understand biochemical pathways and processes. Participants explore various applications of isotopes in experimental techniques and their evolution over time.
  • One participant asks for resources on how radioactive and heavy isotopes are used to label biochemical molecules.
  • Another participant references the Hershey-Chase Experiment as an example of early studies supporting DNA's role in heredity.
  • A participant discusses the use of 3H-thymidine to analyze the duration of mitosis phases, noting that while radioactive compounds are traditional, fluorescent compounds are now more common due to their technical advantages.
  • Another participant mentions the utility of stable isotopes in tracking incorporation and metabolism through mass spectrometry, highlighting recent advancements in sensitivity and resolution.
  • A further contribution suggests the application of pulse labeling in cell biology to track molecules through cellular structures like the ER and Golgi apparatus.
Participants present various viewpoints on the use of radioactive and stable isotopes, with no consensus reached on the superiority of one method over another. The discussion remains open with multiple competing views on the techniques and their applications.
Participants express varying opinions on the relevance and effectiveness of radioactive versus fluorescent compounds, as well as stable isotopes, without resolving the debate on their respective advantages and limitations.
Researchers and students interested in biochemical techniques, isotope applications in science, and advancements in analytical methods may find this discussion relevant.
geordie17
5. Radioactive and heavy isotopes can be used to label biochemical molecules. Describe how their use has enabled scientists to understand biochemical pathways and processes.
Can anyone direct me to any decent websites that might give some info related to this?
Thanks for your help.
Biology news on Phys.org
You could start by looking up the Hershey-Chase Experiment. It was an early study done to provide support for DNA as the info for life.
Nautica
Hi Geordie, think for instance about characterizing the length of time it takes for a cell to go through the different phases of mitosis. By addition of 3H-thymidine you can analyze the rate at which this radioactive base is incorporated in the DNA during the synthesis phase.
But the use of radioactive compounds is becoming an old technique. Now there is a wide range of fluorescent compounds that can be used (although they are generally more expensive). Fluorescence has the technical advantage that it can be quenched, thus leading to new applications. Quenching means silencing the fluorescence.. for an application think about showing that two molecules undergo physical interaction.. if the molecules are apart there will be fluorescence, if they are in close proximity fluorescence will diminish.
Something else that may be of interest.
Stable (non-radioactive) isotopes are also quite useful since you can track the process of incorporation and metabolism via mass spectrometry. So if you expect that if you feed an organism a labeled compound and that it would eventually fully incorporate into a metabolite, you should be able to see that on a mass spectrograph with the m/z ratio increasing. With the advances in mass spectrometry - most notably sensitivity and resolution - in the recent past, it's becoming an incredibly useful analytical technique.
Or how about cell biology where you pulse label certain molecules and follow them how they proceed through the ER and Golgi apparatus etc
  • · Replies 16 ·
