Electric Field and Optics questions
The discussion revolves around two physics problems: one involving electric fields and the other concerning optics related to reflections in a lake. The first problem requires calculating the average power incident on a radio receiving dish and the maximum strength of the magnetic field, while the second problem involves determining the height of a tree based on its reflection in the lake.
  • Mixed
  • Participants explore the relationship between electric and magnetic fields, questioning the assumptions about isotropic transmission and the equations used for calculations. In the optics problem, there is discussion about the geometry of the situation, including the use of similar triangles and the angles of incidence and reflection.
Some participants have offered insights into the equations and concepts related to the electric field problem, while others are clarifying the geometric relationships in the optics problem. There is a recognition of different interpretations of the problems, particularly regarding the visibility of the tree's reflection.
Participants note the lack of specific information regarding the distance from the transmitter in the electric field problem and the assumptions made in the optics problem about the tree's position relative to the lake.
Spectre32
I got a few simpel questions dealing with and electric field and and "optics" question
OK for the electric field we have an object that is out in space. THe max strength of the electric field form the communications tranmissions are 6.8E-10. THe first part of the questiona tell us that the radio receiving dish is 900m^2. We are to find the average power incident on the dish. The second part asks us to find the max strength of the magnetic field for this. For the first part of the question I was going to use the equation I = Eo*Bo/2Uo, and for some reason i can't get it to work. For the second part i was going to use E= cB but again, no luck.
For the second problem there is a lake with a width of 26M. You are staind 3M away from the lake and your eyes are 1.6M above the ground. There a a tree on the other side of the lake, and from your point of view u can only see the top of the tree's reflection in the lake. They want me to find out how tall the tree is. What i did is draw this picture and then draw my rays of the image from the lake to the tree, and then to me. This game me two triangles.( of which one I knew two sides. After figureing out the 3rd side for one of them i went to work on the second one. Yet again i couldn't figure out the height of the tree. I know i am doing something stupid.
Thanks for the help.
Just upchucking some loose thoughts banging around in my head; this may not help you.
Is the transmitter understood to be isotropic? If so, then the energy of the transmission wave would have to drop off as the inverse square of distance. Is the energy of an e.m. wave proportional to the square of intensity? How far is the receiving antenna from the emitting source?
TI's 10billion KM away. It says nothing about Isotropic conditions.Is the energy of an e.m. wave proportional to the square of intensity? The problem dosn't say.
yeah, lol i think that's way to complex for what I'm going for here. My teacher was showing me what was going on with it, but i tired t recreate it and it's not happining.
Okay, I read your question more carefully, and I see that distance from the transmitter is really not an issue.
Here is a simpler site:
http://hyperphysics.phy-astr.gsu.edu/hbase/waves/emwv.html
One of the equations on it is:
S=(E_m)^2/(2 c mu_0).
They don't define E_m (E subscript m) anywhere that I can see, but if it is the "max strength of the electric field", and if S is calculated in units of watts per square meter, then multiplying S by 900 square meters is going to give you some number of watts.
Has your teacher talked about root mean squares (rms)? I am not sure if that is an issue here. Maybe the 2 in the denominator takes into account the averaging of the sinusoidal wave.
As far as your second question goes, I think the critical idea is that the angle of incidence equals the angle of reflection. So your two triangles are similar. Is it fair to say that the right triangle nearest to you has a base of 29 meters and a height of 1.6 meters? And that the top of the tree is seen at the far edge of the pond? It seems to me that this would only allow one to say that the tree satisfies
h/d = 1.6/29
where h is its height and d is its distance beyond the edge of the pond that is farthest from you. You would then have to know how far away the tree is. Have you listed all of the data given for that problem?
If "other side of the lake" means right on the far bank of the lake, can you say that
1.6/3 = h/26 ?
This would mean that you are seeing the top of the tree on the near bank.
That would make a pretty easy equation to solve!
The only problem with this interpretation is that you wouldn't "just see the top" of the tree, would you? I would say in this case you would be able to see the whole danged tree's reflection. If "just see the top" is interpreted as: "you can see the whole tree, but you can't see a humminbird hovering a foot over it," then this is probably the way you are supposed to solve this problem.
well i know the height of the tree is 13.9 M. My teacher game me the answer but i wasn't sure how he got it.
Okay then, the second way I looked at the tree problem does indeed give that answer. One triangle has you as its side (left side, let's say), and the ground from you to the near shore as the base. The other triangle has its right side as the tree, and the pond as its base.
  • · Replies 20 ·
