Net Charge of Cube: -2385075 uC
In summary, the electric field on the surface of a cube is parallel to the z axis, with a magnitude of 37 N/C on the top face and 15 N/C on the bottom face. Using Gauss's law, the net charge contained within the cube is calculated to be -2.385075 * 10^-9 C, with incorrect units of uC. To correct the calculation, the correct values for electric flux and the permittivity constant should be used.
irnubcake
At each point on the surface of a cube the electric field is parallel to the z axis. The length of each edge of the cube is 3.5 m. On the top face of the cube the electric field is in the negative z direction and has a magnitude of 37 N/C magnitude. On the bottom face of the cube the field is in the positive z direction and has a magnitude of 15 N/C. Determine the net charge contained within the cube.
The electric flux at the top face = EA = (-37 N/C)(3.5m)^2 = -453.25 N.m^2/C
At the bottom face = (15 N/C)(3.5m)^2 = 183.75 N.m^2/C
Gauss's law: flux * permittivity constant = charge
Applied on cube: (net flux)(permittivity constant) = net charge
(-269.5 Nm^2/C)(8.85*10^-12) = -2.385075 * 10^-9 C
= -2385075 uC (micro)
Both value and units are incorrect. > < "
Hello,
Basically, you used the correct physical law.
But some mistake is done when the eletric flux was calculated.
The top surface:[tex]\vec{A}_t=3.5^2\hat{z}(m^2)[/tex] and [tex]\vec{E}_t=-37\hat{z}(N^2/C)[/tex].
The bottom surface:[tex]\vec{A}_b=-3.5^2\hat{z}(m^2)[/tex] and [tex]\vec{E}_b=+15\hat{z}(N^2/C)[/tex]
You may use these quantities and try again.
Also notice the constant in Gauss's law:[tex]\oint\vec{E}\cdot d\vec{A}=\frac{Q_\text{total}}{\epsilon_0}[/tex]
Goodluck
I would like to point out that the units for electric flux should be Nm^2, not Nm^2/C. Additionally, the net charge should be a positive value, as the electric field on the bottom face is in the positive z direction. Therefore, the correct calculation would be:
Electric flux at top face = (-37 N/C)(3.5m)^2 = -453.25 Nm^2
Electric flux at bottom face = (15 N/C)(3.5m)^2 = 183.75 Nm^2
Net electric flux = (-269.5 Nm^2) + (183.75 Nm^2) = -85.75 Nm^2
Net charge = (-85.75 Nm^2)(8.85*10^-12) = -7.59*10^-10 C = -759 uC (micro)
Therefore, the net charge contained within the cube is -759 microCoulombs. It is important to pay attention to units and signs when performing calculations in science, as they can greatly affect the accuracy of our results.
What is the net charge of a cube with -2385075 uC?
The net charge of a cube refers to the sum of all the charges contained within the cube. In this case, a cube with a net charge of -2385075 uC means that the total charge within the cube is negative and has a magnitude of 2385075 uC.
What is the unit of measurement for net charge?
The unit of measurement for net charge is coulombs (C). One coulomb is equal to the amount of charge carried by a current of one ampere in one second.
Can a cube have a negative net charge?
Yes, a cube can have a negative net charge. This means that the cube contains a greater amount of negative charges than positive charges.
What factors can affect the net charge of a cube?
The net charge of a cube can be affected by the number and type of particles within the cube, such as protons, neutrons, and electrons. It can also be affected by external factors such as electric fields and contact with other charged objects.
How is the net charge of a cube calculated?
The net charge of a cube is calculated by adding up the individual charges of all the particles within the cube. Positive charges are represented by a plus sign (+) and negative charges by a minus sign (-). The net charge is then expressed in coulombs (C).
