Lorentz-Fitzgerald Contraction or Time Dilation?
The discussion revolves around the interpretation of special relativistic effects, specifically whether Lorentz-Fitzgerald Contraction or Time Dilation provides the correct explanation for phenomena such as the extended lifetime of muons from cosmic rays. Participants explore the implications of using either explanation and the conditions under which each might be applied.
  • Some participants suggest that both Lorentz-Fitzgerald Contraction and Time Dilation can explain the same effects, questioning which is the "correct" answer.
  • One participant asserts that the extended lifetime of muons is a result of Time Dilation, while another challenges this by asking why Time Dilation is preferred over Length Contraction.
  • It is noted that in different reference frames, different explanations may be necessary: Time Dilation in the Earth's frame and Length Contraction in the muon's frame.
  • Another participant emphasizes that neither explanation is "more correct" than the other due to the lack of a preferred frame in relativity.
  • There is a suggestion that both explanations could be valid, and the choice of which to use may depend on the context or derivation involved.
  • A reference to a blog post is made, which discusses the relationship between Lorentz-Fitzgerald Contraction and Time Dilation through clock synchronization.
  • One participant mentions a specific paper by Asher Peres as an example of the problem being discussed.
Participants express disagreement regarding the necessity of choosing one explanation over the other, with some arguing that both can be correct depending on the frame of reference. The discussion remains unresolved as to whether one explanation is preferred or if both are equally valid.
Participants highlight the dependence of explanations on the chosen reference frame, indicating that the context of the discussion may affect the interpretation of the relativistic effects.
Tlatoani
If I can explain a special relativistic effect with both Lorentz-Fitzgerald Contraction and Time Dilation, then which one is the correct answer?
Because, for example in the experiment with the muons coming from the atmosphere, the explanation was Time Dilation, but we can explain it with length contraction too, so which one is the correct answer?
If your are talking about the extended lifetime of the muon, then it is the result of time dilation.
And can you tell me why is it time dilation instead of length contraction?
Both explain the same effect just fine. How do you know when it is length contraction or when it is time dilation?
In different frames there are different explanations--in the Earth's frame you must use time dilation to explain how a muon created by a cosmic ray hitting the upper atmosphere can make it all the way to the surface before decaying, while in the muon's frame you must use length contraction. There is no preferred frame, so neither explanation is "more correct" than the other.
Does the question "If I can explain a special relativistic effect with both Lorentz-Fitzgerald Contraction and Time Dilation, then which one is the correct answer?" suggests that one would be correct and the other would not be correct? Why can't both be correct? Then it woud not matter which explanation was used unless you know something that I do not know. See "https://www.physicsforums.com/blog.php?b=724" " for an explanation that equates Lorentz-Fitzgerald Contraction with Time Dialation via the clock synchronization factor.
This thread is two years old, but I agree: it's not an either-or thing.
If it is about the derivation of a formula which accounts for a special relativistic effect you find in the literature of the subject papers in which it is derived from formulas which account for another relativistic effect. So the addtion law of parallel velocities could be derived invoking length contraction and time dilation, the formula which accounts for the Doppler shift could be derived invoking the formula which accounts for time dilation, the formulas which account for the Lorentz transformtion could be derived from Lorentz contraction...
If you are interested in I could give you a list of such approaches.
I think that Asher Peres' paper "Relativistic telemetry' Am.J.Phys. is a good example for the problem we discuss.
I thought they were.
JesseM provided what I thought was the correct and clear explanation:
  • · Replies 63 ·
  • · Replies 45 ·
  • · Replies 16 ·
  • · Replies 36 ·
