Learning Calculus with Apostol: Reviews & Advice
  • Context: Undergrad
  • Thread starter Thread starter imranq
    Calculus
The discussion revolves around learning calculus, particularly focusing on Apostol's approach to teaching multivariable calculus. Participants share their experiences and opinions on the effectiveness of Apostol's text and whether prior knowledge of single-variable calculus is necessary for understanding multivariable concepts.
  • One participant expresses interest in transitioning from self-studying single-variable calculus to multivariable calculus using Apostol's text, questioning its learning effectiveness.
  • Another participant summarizes four fundamental theorems of single-variable calculus, including the Intermediate Value Theorem, Extreme Value Theorem, Rolle’s Theorem, and the Mean Value Theorem, providing examples for each.
  • A third participant shares their positive experience in understanding the theorems presented, contrasting it with a previous struggle with analysis texts that included complex terminology.
  • A later reply dismisses the previous summary as inadequate, suggesting that the provided information does not encompass all necessary concepts.
Participants do not reach a consensus on the adequacy of the information shared regarding single-variable calculus, with some expressing satisfaction and others challenging the completeness of the explanation.
The discussion highlights varying levels of familiarity with calculus concepts and the potential challenges posed by terminology in advanced texts, but does not resolve these issues.
imranq
I've already self-studied calculus, so I wanted to go on and learn it in multiple variables. Generally, Apostol seems to have had good reviews for 'pure, prose learning', but how is it to actually learn from it? And if I do should I read the single-variable calculus section?
Thanks
calculus in a nutshell:
I will save you some time:
There are 4 principles all calculus of one variable is based on.
I. IVT (Intermediate value theorem) If a function f is continuous on an interval, then the values it takes also form an interval.
Hence if there exist points a,b in the domain interval where f(a) < K < f(b), then f(x) must equal K at some c between a and b.
E.g. the continuous function f(x) = x^3 + x + 1 must equal zero for some x between -1 and 0, since f(-1) = -1, and f(0) = 1.
II. EVT (Extreme value theorem, also called Max Min Value or MMV)
If a function is continuous on a closed bounded interval, then its value also form a closed bounded interval, i.e. particular there is a (finite) smallest and a (finite) largest value.
I.e. if f is continuous on [a,b] then there exist c,d in [a,b] such that for every x in [a,b], f(c) ≤ f(x) ≤ f(d).
E.g. since the volume of the right circular cone of height R+x, inscribed in a sphere of radius R, has volume (π/3)(R^2-x^2)(R+x), is continuous for 0 ≤ x ≤ R, some one of these cones has largest volume.
III. (Rolle’s Theorem) If f is continuous on [a,b] and differentiable on (a,b), and if f(a) = f(b), then f achieves its maximum (or minimum) at a point c between a and b where f’(c) = 0, i.e. at a “critical point” for f.
Cor: If f has two derivatives on [a,b] and f’ takes the same value twice, e.g. if there are two critical points, and if f’’ is zero only a finite number of times, then f has a flex somewhere on (a,b) where f’’=0.
Cor: If f is continuous on [a,b] but has no critical points in the interval (a,b), then f cannot take the same value twice in [a,b], hence cannot change direction, i.e. f is strictly monotone on [a,b].
Cor: If f’’ exists but is never zero on [a,b], then f never changes concavity on [a,b], i.e. f is either concave up or concave down on all of [a,b].
IV. MVT (Mean value theorem) If f is continuous on [a,b] and diffble on (a,b), there is a point c with a<c<b, and f’(c)(b-a) = f(b)-f(a).
Cor: If f’=g’ on [a,b] then f-g is constant on [a,b].
Cor: Since for continuous f, d/dx (integral of f from a to x ) = f(x), then integral of f from a to b = G(b)-G(a), for any G with G’ = f.
Haha, wow, I could actually make sense of all these theorems - awesome.
I have once attempted an analysis text and was overwhelmed with the terminology that was apparently essential to calculus - point-set topology and metric spaces? Etc.
horse poop. i have just given you all the necesities.
  • · Replies 26 ·
