Thread Closed
Change the order of Integrtation
Share Thread Thread Tools
May15-07, 09:37 AM   #1
Change the order of integration and perform the integration.
[tex]\int_0^2\int_{2x}^{4x-x^2} dydx[/tex]
2. Relevant equations
3. The attempt at a solution
I've tried changing it to this but I end up with the wrong answer..
[tex]0<=y<=2, \sqrt{4-y}+2 <=x<=\frac{1}{2}y[/tex]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
May15-07, 09:43 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Sketch the region, what does it look like to you? Have you met polar coordinates yet?
May15-07, 10:20 AM   #3
I've sketched it, it's looks a little cut of a parabola.. I can't see how I can describe it using polar coordinates :/
May15-07, 10:31 AM   #4
Recognitions:
Nevermind, it seems that polar coordinates are not nesscary, but you should reconsider your limits. Lets look at how the region is bounded. We have;
[tex]0\leq x \leq 2[/tex]
[tex]0\leq y \leq 4[/tex]
[tex]x\leq \frac{1}{2}y \equiv y \geq 2x[/tex]
[tex]y \leq 4x-x^2[/tex]
Would you agree?
May15-07, 11:10 AM   #5
Yes, I do agree. What I did was solve the last equation and so I got
[tex]0<=y<=2, \sqrt{4-y}+2 <=x<=\frac{1}{2}y[/tex] ..
Still can't see what I'm doing wrong. I'm kinda slow
May15-07, 11:24 AM   #6
Recognitions:
You've chosen the wrong solution to your equation, [itex]y=4x-x^2[/itex] has two solutions;
[tex]x = 2\pm\sqrt{4-y}[/tex]
Now, your original equation [itex]y=4x-x^2[/itex] goes through the point (x,y)=(0,0), therefore, your new solution must also go through the same point if it is to describe the same region. Which of your solutions goes through the origin?
May15-07, 11:28 AM   #7
Ah, darn I should have seen that! Thank you for being so patient!
May15-07, 11:30 AM   #8
Recognitions:
Quote by Dafe View Post
Nah, its no problem, I didn't spot it at first until I started sketching the region
Thread Closed
Thread Tools
Similar Threads for: Change the order of Integrtation
Thread Forum Replies
Change of order integration Calculus & Beyond Homework 5
Change of integration order? Calculus & Beyond Homework 9
Cycles per instruction question, why different CPI when I change for loop order? Engineering, Comp Sci, & Technology Homework 13
By changing the order would it change the answer? r-combinations Calculus & Beyond Homework 2
integration + change of order Calculus & Beyond Homework 1
