| Thread Closed |
Why the Photon? |
Share Thread | Thread Tools |
| May23-07, 02:10 AM | #35 |
Why the Photon?A reductionistic theory in which the photon is required to have physical reality would throw the balance of probabilities towards realism. As you say its all made up stuff and does not completely hold together. |
| May23-07, 02:50 AM | #36 |
I suspect that quantum systems continuously interact with the rest of the universe and are fully connected to the universe we live in. In order for an observation to be made the effect of an interaction must be amplified into a detectable event. Then there must be somebody there to observer the event. For a “particle” to have physical reality it must have a universe to interact with and be able to reference the magnitude of its physical states. |
| May23-07, 02:58 AM | #37 |
| May23-07, 03:29 AM | #38 |
There is no metric for the Universe. And certainly, the perihelion of Mercury was not calculated with the Minkowski metric. And unquestionably, GPS systems do not use the Minkowski metric. The Minkowski metric is GR’s special case in which one has Newton’s Laws and a finite speed limit theory that is commonly known as, SR. But why photons? Why does matter choose energy in packets? When EM waves are incident upon Hydrogen, is there some mechanism in Hydrogen that says, “we will wait a time ‘t’ dependent upon wave amplitude, to collect ‘E’ energy and then decide what to do with it.”? Or does energy come in packets? I picture particles like billiard balls surround by a potential barrier. When a photon hits Hydrogen, the photon can either, get over the barrier and be absorbed into the center or there is just a collision with the outer barriers. An EM wave of high energy, but low frequency has a bunch of balls, but individually, they are weak and none can penetrate the absorption barrier. These are photons. These are the packets of energy that bombard a target. The target is not bombarded by some solid piece of energy that the target chooses whether to take a bite out of or not and how big the bite should be. I see no contradictions with the photon, GR and Minkowski space. QM showed this interaction with matter and quantized energy and QED was just the next step in saying, well, if EM waves are made of photons, then what about the rest of E&M? And QED has been tremendously successful, although, its greatest triumph of the anomalous magnetic dipole moment of the electron is not nearly as good for the muon. And trying the same strategy to understand gravity in a similar way and make us believe in a graviton has been a failure. While I don’t believe in the graviton, GR reigns supreme here, Einstein was unable to formulate an EM theory with “his” strategy. And QM reigns supreme here. As of today, IMO, the photon is the explanation for the EM forces and GR is the explanation for the gravitational force. BTW, one step in disproving the photon would be to give a new model for the photoelectric effect………….just........for starters. |
| May23-07, 04:58 AM | #39 |
To the best of my knowledge, they do. I have no reference handy, but all algorithms (iterations, Kalmans, etc.) are based on the Minkowski interval. Regards, Dany. |
| May23-07, 05:21 AM | #40 |
Mentor
| May23-07, 06:01 AM | #41 |
The former is locally modelled on Euclid and the latter, as used in GR, locally modelled on Minkowski. The metric in a gravitaional field is Schwarzschild's |
| May23-07, 06:40 AM | #42 |
“Hence, the principle of the constancy of c finds application as the fundamental concept on which the GPS is based. Therefore, to implement Eqs. (1 ), the receiver must generally perform a different rotation for each measurement made, into some common inertial frame, so that Eqs. (1 ) apply. For the GPS it means that synchronization of the entire system of ground-based and orbiting atomic clocks is performed in the local inertial frame, or ECI coordinate system [6].” Etc. I refer to XVX:” There is no metric for the Universe. And certainly, the perihelion of Mercury was not calculated with the Minkowski metric. And unquestionably, GPS systems do not use the Minkowski metric. The Minkowski metric is GR’s special case in which one has Newton’s Laws and a finite speed limit theory that is commonly known as, SR.” I am at holydays now and can’t check about Mercury. I am sure that he is wrong about it too. His statements I consider absurd. Regards, Dany. |
| May23-07, 06:50 AM | #43 |
Mentor
The solution to the precission of the perehilion of Mercury was one of the great successes of GR. This certainly does not use the flat spacetime metric, but instead uses the Schwarzschild metric. You can see this derivation is many GR textbooks if you are not convinced! |
| May23-07, 07:15 AM | #44 |
There is a metric for the universe. It's called the Friedman-Lemaitre-Robertson-Walker metric. See any book on cosmology.
| May23-07, 07:23 AM | #45 |
Regards, Dany. |
| May23-07, 07:29 AM | #46 |
I sincerely cannot understand how you can so easily give real existence to mathematical objects. Yes, QED has been proved up to a very high degree. Does it mean we should believe in the existence of "energy packets" flying from source to detector? Maybe; but maybe someone could, one day, describe the same results with a different theory. Certainly, it's not the case to reject a theory that works so well! But I'm not saying this. What I mean is that I can't understand how can low energy photons exist from source A to detector B if you cannot detect them (because you destroy them in doing it). |
| May23-07, 07:37 AM | #47 |
Mentor
Anyway, this has gotten rather off topic-- I've just noticed that this is a thread in the QP forum! |
| May23-07, 07:52 AM | #48 |
Mentor
So you also have issues with the whole of classical E&M? After all, it IS nothing more than a set of "mathematical objects"? I don't see you complaining about this in the classical physics section whenever classical E&M is discussed. The energy band gap in your semiconductor is also a relic of some mathematical objects. Yet, you freely use it in your electronics. If such a picture doesn't exist, then show me an alternative explanation to the experimental observations that I have mentioned, which, btw, NO ONE has attempted to tackle. Show me a non-photon formulation of the anti-bunching phenomenon and we'll talk. Yet, all we get are nothing more than objections due to a matter of TASTES! This is not physics and this has never been a valid argument against anything in physics. Zz. |
| May23-07, 08:14 AM | #49 |
Mentor
| May23-07, 09:13 AM | #50 |
Thanks for the refs. Few years ago I was involved in the engineering projects connected with GPS. Regards, Dany. |
| May23-07, 09:45 AM | #51 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why the Photon?
| Speed of a photon relative to another photon | Special & General Relativity | 26 | ||
| [SOLVED] photon+deuteron-->p+n , E(photon)=? | Advanced Physics Homework | 4 | ||
| atomic photon versus cavity photon | Quantum Physics | 4 | ||
| Photon-Photon Repulsion-Attraction | Quantum Physics | 12 | ||
| [SOLVED] Photon Power [was Re: Intensity of a Photon] | General Physics | 2 | ||
