| Thread Closed |
Find parametric question for the plane |
Share Thread | Thread Tools |
| May17-07, 12:35 PM | #1 |
Give parametric questions for the plane : 2x-3y+z-6=0 3. The attempt at a solution i know that the normal is (2,-3,1) how do i find the direction vector of the plane? |
| May17-07, 02:59 PM | #2 |
Recognitions:
The plane has two linearly independent 'direction vectors'. Find any two independent vectors perpendicular to your normal.
| May18-07, 07:44 AM | #3 |
Dick is assuming that by 'direction vector', you mean two independent vectors in the plane. I've only seen the term used with lines.
I wonder if you are not confusing this with "find the parametric equations for a line". To do that you would find 'direction vector' for the line. Parametric equations for a plane will involve two parameters. Here, since you can write z as a function of x and y, z= 6- 2x+ 3y, you can use x and y themselves as parameters or, if you prefer distinct variables, x= u, y= w, z= 6- 2u+3w. |
| May18-07, 07:48 AM | #4 |
Recognitions:
That's a much more direct way. I was fixated on the 'direction vector' (basis) picture.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Find parametric question for the plane
| Proton hits infinite charged plane, find charge of plane | Introductory Physics Homework | 1 | ||
| Parametric Representation of a Plane | Calculus & Beyond Homework | 6 | ||
| parametric equation of a line and a plane | Calculus | 1 | ||
| Find plane, given a line & perpendicular plane | Calculus & Beyond Homework | 2 | ||
| How to find out equation of a plane intersecting with other ? | Calculus | 2 | ||
