| Thread Closed |
speed of light |
Share Thread | Thread Tools |
| Mar29-04, 11:53 AM | #35 |
Mentor
speed of light
DrMatrix, you are harping on the fact that the meter is defined by the speed of light and its been explained to you several times now that that is irrelevant to the question of if the speed of light is constant. Exploring this point by Integral a little more may be useful:
In fact, the reason that the meter is no longer defined as the distance between two scratch marks on a bar of metal in France is that since about 20 years ago, our abiliy to measure the speed of light accurately has exceeded our ability to measure the distance between those two scratch marks accurately. As well, due to environmental factors, the distance between those two scratch marks wasn't even constant. The meter had to be re-defined in terms of something more constant/precise or it would hinder scientific research. The speed of light quite literally makes a better meter-stick than the meter-stick does. If you really want to argue arbitrary units, how about the definition of a second...? |
| Mar29-04, 12:05 PM | #36 |
| Mar29-04, 01:39 PM | #37 |
Mentor
| Mar29-04, 01:49 PM | #38 |
Recognitions:
quoting Integral:
quoting Integral: quoting Integral: quoting Creator: quoting Integral: quoting Integral: quoting jdavel: quoting russ_watters: |
| Mar29-04, 01:54 PM | #39 |
Mentor
| Mar29-04, 02:00 PM | #40 |
Recognitions:
| Mar29-04, 02:17 PM | #41 |
Mentor
Suppose I were to define a standard volume of water as the amount of water in a certain bucket. Then using that bucket I measure the volume of several other buckets to be 5 standard buckets. One day I see a new shiny bucket that I would rather use as my standard. When I use my new standard to measure the amount of water in one of the previously measured buckets I find that it now holds 6 standard buckets. Are you telling me I should ignore this discrepancy or should I assume that all buckets have somehow changed? Clearly, if it is indeed used, a change in a standard will be noticed. If the meter were never used to measure anything but the speed of light we would indeed never notice the change. But as soon as we apply the standard to something else we will certainly notice if the standard changes. Suddenly all previous measurements will be wrong according to our standard. |
| Mar29-04, 02:21 PM | #42 |
What is a "known distance"? A distance is known only when compared to the standard of length. The meter is the standard. If the distance to London was 50km and it is now 60km, then the distance to London changed. The meter is still one meter.
Yes I am well aware that GR allows aribtrary coordinates systems. I didn't want to get into that. You can't talk about a constant speed of light in GR. |
| Mar29-04, 02:38 PM | #43 |
Mentor
Precisely, none. General Relativity allows expression of physical laws independent of the coordinate system. "the speed of light is constant because the meter is defined in terms of the wavelength of light? and "The meter is expressed in terms of the wavelengths of light because the speed of light is constant" |
| Mar29-04, 02:49 PM | #44 |
Recognitions:
What if we measured the amount of some water in terms of the number of standard shiney buckets full, and found it to be six one say, and then, the next day, the the amount was only five. Well, then we'd have to discard our conservation of water law, right? No, because, just in the nick of time, a genius comes along with an incredible breakthrough. He (or she; there have been female geniuses, too) declares that the amount of water is not determined by the volume, but by the weight. Now, whenever the water is measured, on whatever day, the weight is always found to be 8.3 standard shiney buckets. Hooray for the inovative minds on the standardization committee! |
| Mar29-04, 03:09 PM | #45 |
Mentor
I feel that there is a issue with the distance changes between cities, if standards mean anything, when I measure a distance in meters it had better read the same today as it did yesterday or next year. That is the whole point of a standard. When London is moving at .5c wrt to Paris then I would expect the distance to change. As long as they are stationary the distance must remain the same. The distance is a physical quantity it does not change with the units you measure it in. |
| Mar29-04, 03:18 PM | #46 |
Recognitions:
By what, I mean the trivial issue of the standard itself. By how, I mean the more significant issue of the method used to compare to the standard. I support the second statement, but it is not an answer to the original post. |
| Mar29-04, 03:37 PM | #47 |
Mentor
Turin,
I am failing to see the point of your posts or your arguments. |
| Mar29-04, 03:43 PM | #48 |
| Mar29-04, 03:43 PM | #49 |
Recognitions:
| Mar29-04, 03:53 PM | #50 |
Mentor
The fact is with modern technology I believe it is easier to get a precise measurement of c then [tex] \epsilon_0[/tex] so it may well be that it is now defined it terms of c then the other way round. That does not change the fact that [tex] \epsilon_0[/tex] is a basic property of space time which is a factor in the propagation of EM waves. Which is the "more" fundamental constant. I personally do not know. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: speed of light
| Can photons be accelated or do they always travel at one speed (speed of light)? | General Physics | 25 | ||
| Light speed....Impossible Faster than light..Probable? | General Physics | 5 | ||
| Real time effects of light, light speed, and the sun? | General Astronomy | 4 | ||
| Speed of light Schmeed of light: things can travel faster | Special & General Relativity | 13 | ||
| Does the Speed of Light Change depending on different Light Frequencies? | General Physics | 15 | ||
