Is the First Expression of Central Force Always Conservative?
  • Context: Graduate
  • Thread starter Thread starter neelakash
    Central force Force
The discussion centers on whether the first expression of a central force is always conservative, contrasting it with a centro-symmetric form. Participants explore the implications of the force's dependence on the position vector and the conditions under which a force can be considered conservative.
  • Some participants assert that the general form of a central force, F(r)=F(r) (r^), is not necessarily conservative due to its dependence on the position vector r.
  • Others question whether the curl operation can be applied similarly to both forms of the central force, expressing confusion about differentiating the r vector within the curl operation.
  • A participant mentions that conservative forces yield path-independent work functions, suggesting that a force must be the gradient of a scalar potential to be considered conservative.
  • One participant introduces a hypothetical scenario involving a ferris wheel to illustrate potential issues with directional dependence in force magnitude, implying that such a force could lead to violations of energy conservation.
  • Another participant acknowledges the discussion and agrees with the points raised about the gradient of f(r) not aligning with r.
Participants express differing views on the conservativeness of the first expression of a central force, indicating that multiple competing perspectives remain unresolved.
Participants highlight the complexity of applying curl operations and the conditions under which forces can be classified as conservative, without reaching a consensus on these points.
neelakash
General form of a central force is F(r)=F(r) (r^)
[Note that This form of central force satisfies L=rxp=0 as well]
But the isotropic or centro-symmetric form is
F(r)=F(r) (r^)
I found in a book that the second form of a central force is conservative.OK,this can be proved easily.What about the first expression?It is NOT centro-symmetric...depends on the position vector r it is acting on.
Why is it NOT conservative always?
Actually,I am not sure whether the same curl operation will do...Please check it...I am getting stuck in the differentiation of the r vector wihin the bracket while taking the curl.I feel confusion if the curl in two cases can be done in exactly similar way.
I don't completely understand your question. Do you need to show that the force of the form
[tex]F(\vec{r}) \hat{e}_r[/tex]
is not conservative while
[tex]F(||\vec{r}||) \hat{e}_r[/tex]
is conservative. Is this what you're trying to do?
NO. L CAN HAVE ANY VALUE.
F(r)=F(r) (r^)
[tex]({\vec k}\cdot{\vec r}){\hat r}[/tex] IS NOT CONSERVATIVE.
[tex]\nabla\times[{\vec r}f({\vec r})]<br /> =-{\vec r}\times\nabla f({\vec r})[/tex].
>>[tex]\mathbf{F}(\mathbf{r}) = f(\mathbf{r})\hat{\mathbf{r}}[/tex]
F(r)=F(r) (r^)
>>[tex]\mathbf{F} = f(r)\hat{\mathbf{r}}[/tex]
Recall that conservative forces yield path independent work functions.
This defines a relative potential difference between any two points as the unambiguous work required to move a test particle between the points.
Thus (unless you let force also be a function of velocity as in EM) the force must be the gradient of a scalar potential (this by --essentially-- the fundamental theorem of calculus). This dictates that for a spherically symmetric force the potential be a function only of the radial coordinate r (not the vector). Thence:
[tex]\mathbf{F}(\mathbf{r}) = \nabla V(r) = V'(r)\nabla r = V'(r)\hat{\mathbf{r}}[/tex]
Intuitively consider that if the force has a directional dependence in magnitude even though the direction is always radial then you could do more work lifting in one direction than in another. Put a "ferris wheel" so that objects going up on one side of the wheel experience less radial force than objects going down on the other side. The wheel will spin faster and faster getting energy from "nowhere". I.e. you have built a perpetual motion machine and are violating conservation of energy.
Electromagnetism gets around this problem because the Lorentz force is always perpendicular to the velocity of the test particle hence no actual work is done by the (magnetic) force. It only redirects the momentum without changing its magnitude.
Regards,
James Baugh
I am sorry as I was unable to keep the touch with you...
siddharth:Yes,you are right...I was talking of that.
Meir Achuz:That is nice...gradient of f(r) is not going to be || to r...In another forum,I found this approach.
jambaugh:A fragrance of physics.Very nice...
  • · Replies 30 ·
  • · Replies 31 ·
