How Do I Calculate the Volume of 6M HCl Needed to Acidify a Mixture to pH ~2?
  • Thread starter Thread starter Endlicheri
    Calculation Ph
The discussion focuses on calculating the volume of 6M HCl required to acidify a mixture of 1g benzaldehyde and 2mL of 10M KOH to achieve a pH of approximately 2. The user correctly identifies the need to account for the moles of benzaldehyde and KOH, leading to the calculation of 1.76 mL of HCl needed for neutralization. However, the user struggles with the relationship between the Cannizzaro reaction and the pH equation, indicating a misunderstanding of the products formed in the reaction. The correct application of the Cannizzaro reaction is essential for accurate pH calculations.
  • Understanding of the Cannizzaro reaction
  • Knowledge of pH calculations and the Henderson-Hasselbalch equation
  • Familiarity with molarity and molar mass calculations
  • Basic acid-base chemistry principles
  • Review the Cannizzaro reaction and its products for benzaldehyde
  • Study the Henderson-Hasselbalch equation for pH calculations
  • Practice molarity and molar mass calculations with various compounds
  • Explore acid-base titration techniques and their applications
Chemistry students, particularly those studying organic chemistry and acid-base reactions, as well as laboratory technicians involved in chemical analysis and pH adjustments.
Endlicheri
I am having difficulties as to what equation to use to calculate the volume. Can someone please kindly give me some help?
What is the volume of 6M HCl required to acidify the mixture of 1g benzaldehyde and 2mL 10M KOH to a pH ~2?
MW of benzaldehyde is 106.1g/mol
cannizzaro reaction: benzaldehyde + KOH + H+ <=> benzoate + benzoic acid
pH = pKa + logQ <- I don't know if this is right to use...
Here is what i think. The volume of HCl needed to acidify should be more than the volume needed to neutralize the solution, so I've calculated the amount needed for neutralization, which is according to my calculation:
Moles of Benzaldehyde
= 1g Benzaldehyde x (1 mol/106.1g)
= 0.009425 mol benzaldehyde
Mole of KOH
= (2 ml x 10 mmol/1ml) x (1 mol/1000 mmol)
= 0.02000 mol KOH
Mole of OH- in excess
= 0.02000 mol KOH – 0.009425 mol Benzaldehyde
= 0.01058 mol OH- in excess
To neutralize, volume of HCl needed
= 0.01058 mol HCl x (1 L HCl/ 6mol HCl) x (1000mL/1L)
= 1.76 mL HCl
But the problem is that I don't know how to relate the equation to the PH equation since KOH and H+ is both on the same side of the chemical equation...
The products of a Cannizzaro reaction of 2 moles of benzaldehyde and hydroxide are not benzoate and benzoic acid. You must correct that before you begin.
10K
13K
  • · Replies 18 ·
9K
