| Thread Closed |
The ethanol deception |
Share Thread | Thread Tools |
| May27-07, 11:50 AM | #52 |
Ivan I'm NOT the one forgetting that we need the corn grown today, that's my whole point. It WILL BE GROWN REGARDLESS OF WHETHER WE TAKE ALCOHOL OUT. You seem to skip over the fact that the only thing taking the alcohol out does is remove the sugars from the corn. It is still quite useful after. I am not favoring ethanol over biodiesel at all. You speak of basic economics. Well here's some food for thought: Right now a corn/soybean crop rotation is fairly common. As there is more demand for corn more of these acres are switched over from soybeans to corn. We now raise corn on the same ground year after year on more acres than previously. This naturally affects the market price of soybeans and some other crops as there are less grown. The same thing will happen if the demand for ethanol goes down and the demand for biodiesel goes up. It will be more profitable to raise soybeans and other biodiesel crops so there will be less corn grown and this shortage will raise the price of corn. Take a look at the market price for both corn and soybeans over the last few years and you will find that they track each other.
- If you don't want fuel to directly compete with food then keep energy production out of agriculture and find some other source for it. |
| May27-07, 03:52 PM | #53 |
- If it wasn't for algae, there would be NO good options ready today that could actually solve the problem. [less nuclear, which I don't see as a practical reality in an age of terrorism even if we could build the plants fast enough, which we can't.] Also, just to avoid any confusion, algae has been a practical option for some time, but it has not been competitive due to price...until now. |
| May27-07, 05:32 PM | #54 |
Ivan where do you get the 1.5 times energy density of biodiesel compared to ethanol? How is that figured?
| May28-07, 05:16 PM | #55 |
Biodiesel has 118330 BTUs per gallon. Ethanol has 76000 BTUs per gallon. This taken with the efficiency of the engine used for each fuel is a direct measure of the work that can be done with each gallon of that fuel. [118/76 ~= 1.5.]. Of course that 1.5 times ignores the greater efficiency of diesel over combustion engines, which makes the comparion even more drastic, as is seen below.
While we are still using regular diesel - as we convert to bio - we get 139,000 BTUs per gallon in engines that are more efficient than gasoline or ethanol powered engines. It begins to help even before we convert to bio. And the diesel cars are here or coming. Diesel engines are already high compression engines, so the comparison is valid even if we consider engines not yet available for ethanol. The higher energy density of bio, the greater efficiency of diesel engines, and the more efficient processing for bio suggests that Bio has about a 400% energy advantage over ethanol - every four gallons of ethanol produced can move a car down the road as far as every gallon of bio produced. |
| May28-07, 05:30 PM | #56 |
Ok. That is pretty much what I expected, but not everything I want to know. How many gallons per bushel of each? And how many bushels per acre of each?
| May28-07, 05:44 PM | #57 |
Note that I have a bunch of late edits in the last post [struggling for clarity]
Most common stats cited for gross yields: Corn yields 400 gallons of ethanol per acre-year. Algae yeilds about 10,000 gallons of biodiesel per acre-year. Net yields [after we pay the energy price to grow and process the fuel]: Corn = 120 gallons per acre-year Algae = 7000 gallons per acre-year I just saw that BBC World News is running a story that asks the question: Should we grow food to feed the world's starving, or grow crops for fuel? |
| May28-07, 06:56 PM | #58 |
| May28-07, 07:54 PM | #59 |
What about soybeans and other biodiesel crops? Also, what is figured in for inputs to the crop? On a corn/soybean rotation it is common to not use fertilizer at all for the soybeans. Plant food is derived from the residue of the previous years crop as well as some of the fertilizer applied for the corn crop. I guarantee you that soybeans on the same ground year after year will require some kind of fertilizer. I know next to nothing about algae but I have a very hard time believing that all it requires is air and sunlight. There must be other input to net the amount of biodiesel we are talking about.
| May28-07, 08:21 PM | #60 |
http://rael.berkeley.edu/EBAMM/. |
| May29-07, 11:46 AM | #61 |
| May29-07, 12:07 PM | #62 |
| May29-07, 12:09 PM | #63 |
Nitrogen and other nutrients are needed for the algae. This was all considered in the aquatic species program and later research. One nice thing about algae is that given the proper selection of algae strains, it can survive and even thrive in highly contaminated water. This is why it can be used to clean-up industrial, ag, and municipal waste. What is considered pollution can grow algae at tremendously high rates. Another part of what makes algae so competitive is the percent yield as a function of oil by weight. There is one strain that has been measured as having as much as 86% oil by weight. Typical yields range between 30 and 50% oil by weight [oil weight compared to weight of dry algae before processing]. And it isn't that hard to understand when you think about it. Algae is a very simply organism that only does a few things. It is also very small - often in the range of about 5 to 10 microns in size - so it is very efficient in that it occupies 100% of the light incident area, and almost all of this is going towards fuel production rather than growing stalks, leaves, etc. |
| May29-07, 12:14 PM | #64 |
In the case of an energy carrier, hydrogen is more efficient as it returns about 50% of the energy used to make it, not 30%. And we don't need corn, just water. Also, hydrogen can be burned in traditional engines. |
| May29-07, 12:36 PM | #65 |
Incidentally, if ethanol has 30% net energy, then that means that it returns 130% of the energy used to make it; not 30%. |
| May29-07, 12:58 PM | #66 |
If we use coal power to make ethanol, yes, it would take less land. Of course we still couldn't grow enough corn. You keep ignoring this point.
Where are we going to get the power? We don't have it, so we would have to either build a tremendous number of coal plants to produce ethanol, or use ethanol energy produced on-site to make the fuel. Either way we need to get the energy from somewhere. When we talk about net energy returns, what we mean is how much of the available energy do we get to use. This is 30%. This is how we measure the net energy gain. You can play games all day, but the energy has to come from somewhere, and ethanol can't provide the energy, so ethanol is not an energy solution, which was the point of this thread. Oh yes, your point about hydrogen is valid. I was using two different ways to compare. With ethanol we put in 66 BTUs and get 100, so we see a 50% gain in this sense. With hydrogen we put in 66 and get back 33 [or so]. |
| May29-07, 01:25 PM | #67 |
Patzek: 27 MJ/L energy input vs. 25 MJ/L energy output = 93% return. Pimentel: 26 MJ/L energy input vs. 23 MJ/L energy output = 88% return. Shapouri: 21 MJ/L energy input vs. 29 MJ/L energy output = 138% return. Graboski: 22 MJ/L energy input vs. 25 MJ/L energy output = 114% return. de Oliviera: 20 MJ/L energy input vs. 25 MJ/L energy output = 125% return. Wang: 19 MJ/L energy input vs. 25.2 MJ/L energy output = 133% return. |
| May29-07, 01:28 PM | #68 |
Currently we have 600 coal plants producing a total of about 22.9 quads of energy annually. All petroleum used has about 38.8 quads of energy with a chain efficiency of about 80%. So we need about 31 quads of energy to replace petro, or 23 quads to make enough ethanol [with a 50% gain based on input power]. So, in order to produce enough ethanol using coal power, we would need about another 600 additional coal plants.
Late edits: I was assuming that we still need to allow for efficiencies already accounted for. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: The ethanol deception
| Ethanol for drinking, Ethanol for fuel. | Chemistry | 7 | ||
| BBC at it again – The Case of the Elaborate Deception | Current Events | 3 | ||
| The Grand Deception: 'Kerry, War Hero,' Is a Myth | Current Events | 137 | ||
| Cosmic Deception: The Hoaxed Alien Invasion Scenario | General Discussion | 7 | ||
| Weapon of Mass Deception; Depleted Uranium | Current Events | 24 | ||
