Vectors: Motion in a plane
by mohdhm
Tags: motion, plane, vectors
mohdhm
mohdhm is offline
#1
May28-07, 11:47 AM
P: 42
1)
A particle starts form the origin at t=0 with an initial velocity having an x compoent and a y component. the particle moves in the xy plane with an x component of acceleration only
a)
Determine the components of velocity vector at any time and the total velocity vector at any time
Given Info: Vxi=20m/s, Vyi=-15m/s, Ax=4.0m/s^2, Ay=0.
Solved.
Answer: Vf=Vxi+Vyi = [(20+4.0t)(i hat symbol?) - 15(j hat symbol?)]m/s
b) calculate the velocity and speed of the particle at t=5?
Ok the tricky part... both velocity and speed have the same magnitude because with 2 dimensions you have to use the pythagorean theorm to add the magnitude of the x and y components. I also concluded that vector = speed but with theta(direction).
solved the problem for part B.
c) determine the x and y coordinate of the particle at any time t and the position vector of this time.
xf=vit=1/2at^2= (20t+2.0t^2)m
yf=vit=(-15t)m
so the position vector at any time t is [(20t+2.0t^2)i -15tj]m
Then the example question says.. lets test it out. and gives me some values
at t=5, x=150, y=-75
what is the magnitude of the displacement?
rf=sqrt[(150^2+(-75)^2]=170m
"note that this isnot the distance that the particle travels in this time! Can you determine the distance from the available data?
Now how do you determine the distance at t=5 ? do you just add the vector components of distance? If someone can please answer that last question, i could rest my mind
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
Doc Al
Doc Al is offline
#2
May28-07, 02:07 PM
Mentor
Doc Al's Avatar
P: 40,872
Quote Quote by mohdhm View Post
I assume you mean add the components of the displacement. No, that won't do. Hint: Find an expression for the speed of the particle as a function of time.
mohdhm
mohdhm is offline
#3
May28-07, 10:04 PM
P: 42
so you find the intergral of Vx and Vy and add them up?
d(t)=Velocity * integral of 0 to 5 where f(x) is dt ?
Doc Al
Doc Al is offline
#4
May29-07, 09:37 AM
Mentor
Doc Al's Avatar
P: 40,872
Find an expression for the speed of the particle and integrate that from t = 0 to 5 seconds. What's the speed as a function of time?
mohdhm
mohdhm is offline
#5
Jun2-07, 01:18 AM
P: 42
finding the integral of vf=vi+at gives me d= vit+1/2at^2 and we just solve from there... using the absolute value...
i integrated the vf=vi+at and got the expected d=vit+1/2at^2 which gives me DISPLACEMENT
What is the distance, what is the solution of this problem.
Register to reply
Related Discussions
Z plane in vectors Introductory Physics Homework 5
Vectors in the Plane: Plane+Wind question.. Precalculus Mathematics Homework 2
Motion in a Plane Introductory Physics Homework 9
Telling if three vectors in the same plane?? Help! Precalculus Mathematics Homework 5
Motion in a Plane question dealing with circular motion Introductory Physics Homework 11
