Back E.M.F. & Torque Output of a Permanent Magnet DC Motor
The discussion centers on the effect of back electromotive force (back e.m.f.) on the torque output of a permanent magnet DC motor. Participants explore the relationship between back e.m.f., armature rotation, and torque, with a focus on the underlying principles and mechanics involved.
  • Some participants explain that back e.m.f. is generated when the armature of the DC motor rotates, acting as a generator and producing a counter e.m.f. that is proportional to the armature's speed.
  • It is noted that at a certain speed, back e.m.f. equals the applied voltage, which represents the maximum speed of the motor.
  • Participants mention that at startup, back e.m.f. is zero, leading to maximum voltage across the armature and consequently maximum current and torque.
  • As the speed of the motor increases, back e.m.f. rises, resulting in a decrease in voltage across the armature, which leads to a reduction in current and torque.
  • Finally, it is stated that at maximum speed, when applied voltage equals back e.m.f., the motor draws no current and produces no torque.
Participants generally agree on the relationship between back e.m.f., current, and torque output in a DC motor, but the discussion does not explore any competing views or unresolved questions.
The discussion does not address potential limitations or assumptions regarding the definitions of terms or the conditions under which the described relationships hold.
Readers interested in the mechanics of DC motors, electrical engineering concepts, or those seeking clarification on the role of back e.m.f. in motor operation may find this discussion relevant.
OutCell
Hi,
What is the effect of "back e.m.f." on the torque output of a permanent magnet d.c. motor? I googled it but didn't get any results.. I just need a brief description to understand the concept..
Thanks :blushing:
when armature of dc motor rotates, it also acts as a generator also n generates a counter emf(lenz law) which is called back emf. now this back emf is proportional to the speed at which the armature is rotating. at a particular speed it becomes equal to the applied voltage. this is the maximum speed of the dc motor.
at the start, when back emf is zero, voltage across armature(applied voltage-back emf) is maximum, current is maximum, therefore torque is maximum(torque is proportional to current in the armature, T = I*L*B*r, I current, L length of conductor,B magnetic field, r = radius, school physics). as the speed builds up, back emf increases, voltage across armature drops, current drops and therefore torque starts to decrease.
finally when speed is maximum, ie applied voltage= back emf, no current, no torque. therefore at no load n maximum speed, motor has no torque
Thanks mate! :rolleyes:
no probs dude. pleasure to help u
