Solving Zener Circuit: Vs=50V, Vz=10V, Iz=32mA, R1=1K Ohm
  • Thread starter Thread starter cowgiljl
    Circuit
The discussion focuses on solving a Zener circuit with a source voltage (Vs) of 50V, Zener voltage (Vz) of 10V, Zener current (Iz) of 32mA, and a series resistor (R1) of 1K ohm. The user calculates the load resistor (Rl) to be approximately 556 ohms, with a load current (Il) of 18mA derived from the total current of 50mA minus the Zener current. The user seeks confirmation of these calculations and guidance on determining the range of Rl.
  • Understanding of Zener diode operation and characteristics
  • Familiarity with circuit analysis techniques, specifically series and parallel circuits
  • Proficiency in using Multisim for circuit simulation
  • Knowledge of Ohm's Law and current calculations
  • Explore Zener diode voltage regulation techniques
  • Learn how to simulate circuits using Multisim
  • Research methods for calculating load resistor ranges in Zener circuits
  • Study the impact of varying load conditions on Zener diode performance
Electrical engineers, electronics students, and hobbyists working with Zener circuits and voltage regulation techniques.
cowgiljl
This is what i have so far the knowns
Vs= 50v
Vz = 10 v
Iz = 32mA
R1 = 1K ohm
Rl =? "potentmeter"
i just got the multisim program and could draw the cir if need be
R1 is in series with the source and the zener and rl are in parallel
it wants me to determine the range of Rl, Il, Vrl
I havew so far is 50 /1K = 50mA
Vrl = 10 v
I l = 50mA-32 mA = 18 mA
Rl = 556 ohms
is this correct and how would i go about finding the range of Rl
thanks joe
To be certain, I need you to draw it.
thanks i found a pretty good example in an old text i had
thanks again
joe
13K
