Proving the Divergence of a Sequence
  • Context: Undergrad
  • Thread starter Thread starter Claire84
    Divergence Sequence
The discussion revolves around proving the divergence of the sequence defined by \( x_n = (-1)^n \) for natural numbers \( n \). Participants explore various approaches to demonstrate that the sequence does not converge, including the use of epsilon arguments and subsequences.
  • Homework-related
  • One participant begins by attempting to prove divergence by assuming convergence and applying the epsilon definition, but struggles to find a contradiction.
  • Another participant points out that the sequence has convergent subsequences (even terms to 1 and odd terms to -1), suggesting that the sequence cannot converge overall.
  • Several participants express frustration with the complexity of the problem, indicating that they are still learning analysis concepts.
  • A participant outlines a formal approach to proving divergence by contradiction, using specific cases for positive and negative limits and epsilon values.
  • There is a clarification that the original question pertains to a sequence rather than a series, which leads to some confusion among participants.
  • Later, a participant asks about proving the convergence of the absolute values of the sequence, leading to further exploration of inequalities related to absolute values.
  • Another participant provides a useful inequality involving absolute values, which is acknowledged by others as a helpful tool.
Participants generally agree that the sequence diverges, but there are multiple approaches and some confusion regarding the definitions and methods used. The discussion remains unresolved in terms of a single clear method for proving divergence.
Some participants express uncertainty about the application of epsilon arguments and the validity of certain steps in their reasoning. There is also a noted distinction between sequences and series, which contributes to the complexity of the discussion.
Students and learners in mathematical analysis, particularly those grappling with concepts of convergence and divergence in sequences.
Claire84
Hey there, one of our h/work questions is to prove that a certain sequence is divergent, where xn=(-1)^n for every natural n. I started off by assuming that it was infact convergent so wrote that mod(xn/l)<e where e is any real number greater than zero, and this holds for any n>no. But from the one example we did in class, it seems you can choose your e to make things a little easier for yourself and then choose k and k+1 both greater than no to allow you to obtain the contradiction that you need. I mean I started to try things like mod(xn/l)<1 and then choose mod(xk-l)<1 and (xk+2-1)<1. Then I had 2=mod((k+2)-k) which was equal to mod(xk+2 +xk) but this clearly doesn't seem to get me anywhere (well not from where I'm sitting). I've been trying stuff like this but can't seem to get anything to work. Could someone please put me in the right direction? Thanks!
Btw, when I've written stuff like xk+2 I just mean xsubscript k+2 :smile:
it has a convergent subsequence - for n even the subsequence tends to 1. It also has the odd terms converging to -1. thus the sequence cannot converge or any two subsequences must converge and converge to the same thing. No need to use epsilon, but we can do it that way if we must, it's just messy, the start there is to suppose ti converges to x, if x is positive do something with e= 1/2 and the odd terms, if x is -ve do it with e=1/2 and the even terms.
Pfft why do they give us a messy one to prove? We're only analysis babies!
So I've said mod(xn-l)<1/2 for all n>no, so l is what it's converging to (just what I'm used too).
Now we take mod(xk-l)<1/2 and mod(xk+1)<1/2
Taking the situation first where k is an even power so the limit is negative we have
mod(1+l)<1/2 and mod(-1+l)<1/2
Then have 1=mod((1+l)-l)<mod((1+l)+(-l+1))<mod(1+l)+mod(-l+1)<1/2 +1/2<1 which obv doesn't make sense, but I think this is v.wrong. Ooops.
Remember you order of qunatifiers.
to show x(n) converges means
there is an x
such that
for all e>0
there is an N(e)
such that
for all n>N(e)
|x(n) - x| <e
To show it does not converge
for all x
there is an e
such that
for all N(e)
there is an n>N(e)
with |x(n)-x| >e
So to show it does not converge (without using our brains) we say, suppose x is arbitary.
case 1 x positive, let e =1/2, then for any N, take the next odd number greater than N, say it is n, then |x_n-x| >1/2 cos x_n is -1 and every positive number is more than 1/2 away from -1
case 2 if x is negative, let e=1/2, then for any N take the next even number after N, call it n, then |x_n-x|>1/2 cos every negative number is mroe than 1/2 away from 1.
If you want to be formal:
Assume (by contradiction) that the series converges to some value [tex]s[/tex]. Then given any [tex]\epsilon > 0[/tex] there must be some [tex]N[/tex] such that [tex]n>N \rightarrow |s-\sum_{i=1}{n}(-1}^i|<e[/tex]. Now if [tex]\epsilon<0.5[/tex] consider that [tex]|\sum_{i=1}{N+1}(-1)^i-\sum_{i=1}{N+1}(-1)^i|=1[/tex] and that [tex]\sum_{i=1}{N+1}(-1)^i = s + e_1[/tex] and [tex]\sum_{i=1}{N+1}(-1)^i=s-e_2[/tex] where [tex]|e_1|,|e_2| < \epsilon[/tex] so by the triangle inequality [tex]|e_1+e_2|<2 \epsilon < 1[/tex] but by substitution we also have [tex]|\sum_{i=1}{N+1}(-1)^i-\sum_{i=1}{N+1}(-1)^i|=|s + e_1 - (s - e_2)| = |e_1 + e_2| = 1[/tex] this is a contradiction therefore the inital assumption must be incorrect.
If you understand this, you should have no trouble generalizing it to include all series [tex]\sum a_i[/tex] where [tex]\lim_{i \rightarrow \infty} a_i \neq 0[/tex]
but the question wasn't on series.
Okies, thanks for that I'm pleasantly surprised by how much simpler it was than I first thought!
Just one more ickle quiestion. If we have xn tending to l as n tends to infinity, how do we prove that modxn tends to mod(l) as n tends to infinity.
So we have mod(xn-l)<e for all n>N
Then I put mod(xn-l)>mod(xn)-mod(l) although that was a tad pointless I think... Then I put mod(xn-l)>=mod(mod(xn)-mod(l)) but I'm not sure if that's valid or not...
Use the folllowing inequality:
||x|-|y|| < |x-y|
Thanks, I didn't know that existed. I'd only ever seen the triangle one before, but never that one. Is there any way of proving it? Sorry, I'm being a pain. Thanks again! :wink:
It follows from the triangle inequality:
|x| = |x-y+y| < |x-y| + |y|
so |x|-|y| < |x-y|
and by symmetry
|y|-|x|<|y-x|=|x-y|
so -|x-y| <|x|-|y| < |x-y|
ie ||x|-|y|| < |x-y|
  • · Replies 17 ·
  • · Replies 24 ·
