Knocking the bottom of the bottle.
  • Thread starter Thread starter Petrulis
The discussion revolves around the physics of knocking out the bottom of a vitreous bottle filled with water by striking the top. The key conclusion is that the force applied at the top of the bottle is magnified at the bottom due to the difference in area between the neck and the bottom. The evaluation of the force is based on the equation Force bottom = (M*v/t) * (bottom area / neck area), confirming that the calculations align with Newton's Third Law. The participants agree on the correctness of the pressure equations and the derived forces.
  • Understanding of Newton's Third Law of Motion
  • Basic knowledge of pressure equations in fluid mechanics
  • Familiarity with force, mass, and acceleration relationships
  • Concept of area ratios in physics
  • Study fluid dynamics principles related to pressure and force transmission
  • Learn about Newton's Laws of Motion in greater detail
  • Explore the concept of impulse and momentum in physics
  • Investigate practical applications of pressure differentials in engineering
Physics students, educators, and anyone interested in understanding the mechanics of force and pressure in fluid systems.
Petrulis
If vitreous bottle is full of water and we strike with a palm from the top to the bottleneck, we can knock out the bottom of the bottle. Why? How to evaluate the force which knocks out the bottom of the bottle?
Because water has constant pressure:
Pressure on the top = Force applied / neck area​
Pressure on the bottom = Force bottom/ bottom area​
Force bottom = Force top * bottom area / neck area​
So we knock out the bottom of the bottle because the force gets magnified. Now I need to evaluate "Force top".
Let's say that the mass of the palm is M, and it moves with speed v before strike. The strike takes time moment which is equal to t.
So then this means that:
Force top = M*v/t​
And we get that:
Force bottom = M*v/t * bottom area / neck area​
So is the "Force bottom" evaluated correctly in this problem? Don't I miss anything?
Thanks in advance.
Its looks pretty good. Your pressure equation is right. Then you find the acceleration and force on the hand, which has to be equal to the force on the top of the bottle:
For the hand:
v_i=-v
v_f=0
t=t
[tex]v_f=v_i+at[/tex]
so [tex]a =\frac{-v_i}{t} =\frac{v}{t}[/tex]
Then the force on the hand becomes:
[tex]F=ma=\frac{mv}{t}[/tex]
Which is equal to the force on the top of the bottle by Newton's Third Law.
Yup looks good to me.
