Radius of proton given radius of electron
The discussion centers on calculating the radius of a proton given the radius of an electron using classical physics principles. The participant utilized the formula for centripetal force, F = (mv²)/r, to derive the proton's radius as 2000 times that of the electron's radius. The calculations involved constants such as the charge of an electron (1.6 x 10^-19 C) and the mass of an electron (9.1 x 10^-31 kg). The final conclusion confirms that the ratio of the radii is directly proportional to the ratio of their masses.
  • Understanding of classical mechanics, specifically centripetal force.
  • Familiarity with the right-hand rule for determining direction of forces.
  • Knowledge of fundamental constants such as the charge and mass of an electron.
  • Ability to manipulate algebraic equations involving ratios and proportions.
  • Study the derivation of centripetal force equations in classical mechanics.
  • Explore the implications of mass-radius ratios in particle physics.
  • Learn about the properties of protons and electrons, including their charge and mass.
  • Investigate the role of electromagnetic forces in particle interactions.
Students in physics, particularly those studying electromagnetism and particle physics, as well as educators looking for practical examples of force calculations in atomic structures.
t_n_p
http://img518.imageshack.us/img518/9337/untitled2gr1.jpg
(a) Using the right hand rule, my sketch looks like the following
http://img340.imageshack.us/img340/5530/untitled3mk0.jpg
(b) F=qvbsin(theta)
F=(1.6*10^-19)*(5*10^7)*(0.5)*sin(90deg)
F= 4*10^-12 Newtons
(c) Using F = (mv²)/r
4*10^-12 = [(9.1*10^-31)*(5*10^7)²]/r
r = 5.7*10^-4 m
(d) I used the formula [Rp/Re] = [MpVp]/[MeVe], but the final answer is simply a radius which is 2000 times that of the electron. For some reason, I don't think it's right!
(d)
[tex]F_e = F_p[/tex]
therefore
[tex]\frac{m_e v^2}{r_e} = \frac{m_p v^2}{r_p}[/tex]
giving
[tex]\frac{r_e}{m_e} = \frac{r_p}{m_p}[/tex]
so that
[tex]\frac{m_p}{m_e} r_e = r_p[/tex]
or
[tex]r_p = 2000\ r_e[/tex]
hmm so I was right! :smile:
9K
