Solve for n: Positive Integer Sequence with Greatest Divisor and LCM
  • Context: Graduate
The discussion revolves around identifying values of n (where n is a positive integer greater than or equal to 2) for which there exists a sequence of positive integers such that the greatest number in the set divides the least common multiple (LCM) of all the other numbers in the sequence. The scope includes theoretical exploration and mathematical reasoning.
  • One participant questions for what values of n there exists a sequence of integers such that the greatest number divides the LCM of the others.
  • Another participant proposes that if n is prime, it may be impossible to find numbers less than n whose product is divisible by n, and suggests exploring constraints on prime factors if n is not prime.
  • Questions arise about the clarity of the initial problem statement, particularly regarding whether n refers to the largest number in the sequence or the number of terms.
  • It is suggested that if n is prime, there cannot be a subset of numbers whose LCM is divisible by n, as no subset can have a product divisible by n.
  • A participant introduces a potential solution involving distinct primes and their products, indicating that for composite n, the LCM of a certain set of integers can be divisible by n.
  • Another participant shares a detailed answer from an external source regarding the conditions under which the LCM of a sequence can be divisible by n, including specific cases for prime and composite n.
Participants express uncertainty and seek clarification on the definition of n and the structure of the sequence. There is no consensus on the implications of n being prime or composite, and multiple competing views remain regarding the conditions for divisibility and the nature of the sequence.
Participants note the ambiguity in the initial question and the need for clearer definitions of terms such as "sequence" and the role of n. Some mathematical steps and assumptions remain unresolved, particularly regarding the implications of n being prime or composite.
quddusaliquddus
for what values of n (where n is >=2) is there a sequnce of integers-positive so that the greatest num in the set divides the LCM of all the numbers left? :cool:
Suppose n is prime, is there anyway of finding numbers less than n whose product is divisible by n? If n is not prime could you find some constraint on its prime factors?
questions...answers...and questions...
Question 1) I am not sure, but whatever number <= n e.g. M, multiplied by n e.g. M*n should give you a number. Any number divisable by n (prime) would have to have n as a factor wouldn't it? Does this mean you can't have numbers <=n when n is prime whose products are divisable by n?
Question 2) I'll have a look at that. :biggrin:
Well, you initial question starts off by mentioning n, and then doesn't use n at all in the second part when you set up the problem, so it's a little vague. And what sequences are allowed?
I took it to mean: suppose S is some set of numbers between 1 and n (not inclusive of n) wthout repetition. When can the lcm of the elements of S be divisible by n.
If n is prime, there is no subset of 1...n whose lcm is divisible by n, as there is no subset whose product is divisible by n, and the lcm divides the product.
Try it for some examples of n, and please clear up what you mean.
Examples,
n=6 S={2,3} the lcm is divisible by 6
n=9 there is no subset whose lcm is divisible by 9.
ok.......
But do you admit that you say: let n be an integer greater than 2, and then go on to ask a question that is independent of n? Could you rewrite the question?
there's nothing to admit other than i might've done mistakes
Sorry, just trying to get you to say if n is tha largest number in the sequence or if it is the number of terms in the sequence. I couldn't decide what "ok..." meant.
i tried to type "ok" but it didint lemme...i typed some fullstops to satisfy the 12-letter rule (spaces also don't work)
Answer...
I don't know if you guys want to see the answer. But i think I've got it...bty...i didnt do it. Someone else helped me. if anyone's interested in seeing the answer...lemme know. I ask cos its a little long.
You're stilll not to my mind cleared up the question - is n the number of terms in the sequence or the largest term in the sequence? The answer is relatively straight forward in either case.
I wish i could say its easy...lol. n is the number of numbers.
But then unless you define the concept of 'sequence' oddly the answer is all n>2:
let p_i i =1,...n-1 be a set of n-1 distinct primes (this forms a sequence), then p_1, p_2...P_{n-1},q will do where q is the product of p_1...p_{n-1}
This is an answer i got somewhere else. Thought you might like to look at it:
" suppose n=p*q is composite, p,q>1, gcd(p,q)=1. then consider S={1,2,...,n}
then p,q belongs to S
hence p|LCM{1,2,...,n-1}
q|LCM{1,2,...,n-1}
since gcd(p,q)=1, then n=p*q|LCM{1,2,...,n-1}
suppose n=p^k, where p is odd prime
by Catalan's Theorem, then only two powers (greater than 1) differ by 1 is 2^3+1=3^2
and we have p^k+1 is divisible by 2 hence non prime
for the case p=2 k=3, we take {3,4,5,6,7,8,9,10}
otherwise
S={2,...,p^k,p^k+1} has p^(2k+1)+1 factors to u,v such that u*v=1 and we are done.
still think about the case where n=p... and n=2^k "
So it looks as though you mean n conescutive numbers then.
yeah.sorry.
  • · Replies 16 ·
  • · Replies 80 ·
10K
