Thermodynamics Calculation
by skpmobile
Tags: calculation, thermodynamics
skpmobile
skpmobile is offline
#1
Jun14-07, 11:08 PM
P: 6
Base temperature 68F
BTU - 8000
Cubic Feet of Air -10000
Coolign mechanism fails.
No air circulation.
Closed air space.
Starting at 68F what is the formula to calculate the temperature curve over time?
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
Danger
Danger is offline
#2
Jun14-07, 11:31 PM
PF Gold
Danger's Avatar
P: 8,961
Welcome to PF, Skpmobile, but please don't double-post. You've already asked this in General Physics. It will be dealt with when someone with the answer gets around to it. I don't know it myself.
Jack111
Jack111 is offline
#3
Jun15-07, 03:16 AM
P: 9
F? BTU? cubic feet?
Sounds like Newton's law of cooling here but you're going to need to flesh it out a bit and convert all units to SI first
Astronuc
Astronuc is offline
#4
Jun15-07, 06:46 AM
Admin
Astronuc's Avatar
P: 21,637
Quote Quote by skpmobile View Post
BTU - 8000
No air circulation.
Closed air space.
I'm afraid I cannot make sense of the problem as posed. What is supposed to happen with 8000 BTU?
Cooling mechanism fails? If there is no heat transfer, there is no temperature change.
No air circulation would imply no convection.
Radiative heat transfer would occur, but that is very slow, and it depends on the temperature differential or rather Thot4-Tcold4
Without radiation and convection, one is left with conduction, but the problem states no cooling.
Does the problem infer putting 8000 BTU into 10000 cu ft of air with adiabtic boundary conditions?
FredGarvin
FredGarvin is offline
#5
Jun15-07, 06:51 AM
Sci Advisor
FredGarvin's Avatar
P: 5,095
That's the way I am reading it. A 10,000 ft^3 volume at an initial 68°F with a Q = 8000 BTU input.
First Law stuff.
skpmobile
#6
Jun15-07, 10:17 AM
P: 6
Quote Quote by Astronuc View Post
For Example:
I have a room with 8000 cubic feet of air in the room
There is equipment in the room that is generating 100BTUs
I currently have chillers in that room to cool it to 68F
If those chillers fail starting at 68F what would be the temperature increase over time?
Astronuc
Astronuc is offline
#7
Jun15-07, 10:37 AM
Admin
Astronuc's Avatar
P: 21,637
OK - that is a better description of the problem. It can be handled by a 'lump parameter' model, i.e. time dependent heat transfer in basically zero dimensions.
One is looking at heat source and loss of heat transfer from the system, so the internal energy, and therefore temperature, increases with time.
skpmobile
#8
Jun15-07, 10:45 AM
P: 6
Great, so what equation would i plug those paraketers into to calculate points on the curve?
Astronuc
Astronuc is offline
#9
Jun15-07, 08:42 PM
Admin
Astronuc's Avatar
P: 21,637
Well, are the chillers failing one by one, or all together.
One has to determine the rate at which energy is accumulating, which is the difference between heat generation and heat loss. Then relate that to specific heat of the air.
I could be as simple as - http://hyperphysics.phy-astr.gsu.edu...ermo/spht.html
http://hyperphysics.phy-astr.gsu.edu...ic/shegas.html
Think about how to make [tex]Q\,=\,cm\Delta{T}[/tex] time dependent.
skpmobile
#10
Jun17-07, 08:27 PM
P: 6
Points of clarification:
- fixed volume of air (closed room)
-starting air temperature is 68F
-cubic feet is the measurement of the air
-standard air
-no air movement generated with the exception of thermally generated
movement
-chillers all fail at once (instant loss of cooling ability)
- Thermal factor (BTU) derived from equipment documentation
-maximum for that equipment (looking at a worst case scenario)
So if I understand your statement I would have a constant level of heat being generated (the BTUs) and no heat loss from that environment. So I am looking at generating a curve of heat increase, so my x axis is time ( 1 minute increments ) and my y axis is temperature ( 1 degree increments ) where do I go from here?
quark
quark is offline
#11
Jun20-07, 10:23 PM
P: 230
The equipment rating should be in btu/hr rather than btu. Use the formula Q = 1.1xcfmxdT. As you have no air circulation, after adding up all the heatloads in the room and getting the total heat input in btu/hr, divide the room volume by 60. This gives you the temperature rise per minute.
skpmobile
#12
Jun22-07, 03:31 PM
P: 6
Gentlemen, I am a total laymen relative to physics would you be so kind as to plug my original numbers into the appropriate places in the equation so I have a clearer picture. Your assistance is greatly appreciated.
skpmobile
#13
Jun22-07, 04:41 PM
P: 6
Astronuc, I finally think I am getting it I just don't know how to determine time by the equation.
284064031.4........ 21851079.33........ 1.3........ 10
Q....................... C......................Mass of.....Temperature
................................................Air at SL.....Delta
Danger
Danger is offline
#14
Jun23-07, 02:16 AM
PF Gold
Danger's Avatar
P: 8,961
Once you start plugging things into parakeets, you're out of the realm of physics and getting into abnormal psychology. There are people here who can help you with that as well.
Register to reply
Related Discussions
Prof teaches Statistical thermodynamics in a Classical Thermodynamics class Academic Guidance 10
Sum calculation Calculus 8
I need help with a calculation please General Physics 3
pH calculation Biology, Chemistry & Other Homework 10
calculation help Precalculus Mathematics Homework 2
