How Is Friction Calculated for a Scrambler Car That Stops After 10 Meters?
  • Thread starter Thread starter pineapple629
    Friction
The discussion revolves around calculating the friction acting on a scrambler car that comes to a stop after traveling 10 meters. The problem involves concepts from mechanics, particularly the forces acting on the car during its motion.
  • Participants discuss using energy principles to relate friction to mechanical energy changes. There are attempts to apply equations involving work done by friction and the relationship between mass, gravitational force, and distance traveled. Questions arise regarding the values used for friction and the interpretation of results obtained from calculations.
The discussion is ongoing, with participants exploring different methods to calculate friction. Some guidance has been offered regarding the use of energy equations, but there is no clear consensus on the values or methods being applied. Confusion exists around specific calculations and the meaning of derived quantities.
Participants are focusing solely on the 10 meters traveled after launch, and there is mention of potential friction in the initial acceleration phase. The discussion includes uncertainty about the values used for mass and gravitational force in the calculations.
pineapple629
we need to find the friction of our car after we launch it. it rolls to a stop at 10 meters.
http://home.comcast.net/~jay7042/physics.bmp
initial velocity after it laucnhed is 1.25 m/s
distance traveld 10m in 7s
we need to find the friction and efficiency of the car
Use energies. The only non-preserving force that operates in the system is the friction, and its work is equal to the change of mechanical energy of the whole system:
[tex]W_f = \Delta E_m = (\Delta E_k) + (\Delta E_p)[/tex]
[tex]-fX = (0 - 0) + (0 - mgh) = -Mgh[/tex]
Where M is the mass of the weight, and X is the total distance the car travels (1m + 10m), assuming there is also friction in the acceleration area (the 1m inside the structure). If there is no friction in that segment, then X is just 10m.
we are only going to calculate the 10m after it launched. i plugged my numbers into the bottom equation as best as i could and got -.023*10 = (-.178*9.8*1) = 1.97 now I am confused what 1.97 is
Where did you come up with 0.023N as the friction force? I thought that's what you were going to find.
[tex]-fX = -Mgh[/tex]
Therefore:
[tex]f = \frac{Mgh}{x} = \frac{2kg10\frac{m}{s^2}1m}{10m}[/tex]
  • · Replies 60 ·
