What is a Hilbert Transform and How Does it Work?
The Hilbert Transform (HT) is an integral transform utilized for analyzing narrow band signals, providing a 90-degree phase shift for each frequency component. In the context of vibration analysis, particularly in gearbox diagnostics, the HT is employed to compute the envelope of a signal, represented mathematically as s(t)=[[b(t)+i[H(b(t))]]], where b(t) is the band-pass filtered signal. This technique is crucial for envelope detection, allowing for the extraction of the instantaneous envelope from amplitude-modulated signals, thereby enhancing signal processing capabilities.
  • Understanding of integral transforms, specifically Hilbert Transform
  • Familiarity with signal processing concepts, particularly envelope detection
  • Knowledge of band-pass filtering techniques
  • Basic mathematical skills for interpreting signal equations
  • Study the mathematical properties of the Hilbert Transform in detail
  • Explore practical applications of envelope detection in signal processing
  • Learn about band-pass filtering techniques and their implementation
  • Investigate the use of Hilbert Transform in vibration analysis for machinery diagnostics
Engineers, signal processing specialists, and researchers in the field of vibration analysis and diagnostics who are looking to enhance their understanding of the Hilbert Transform and its applications in real-world scenarios.
enigma
Staff Emeritus
Anybody know what a Hilbert transform does?
NB4 uses the envelope of the signal, band-pass filtered about the mesh frequency. The envelope, s, is computed using the Hilbert transform and is given by:
[tex]s(t)=[[b(t)+i[H(b(t))]]][/tex]
Where b(t) is the signal band-pass filtered about the mesh frequency. H(b(t)) is the Hilbert transform of b(t) and i is the sample index.
A Review of Vibration Based Techniques for Helicopter Transmission Diagnostics by Paul D. Samuel and Darryll J. Pines, p19
The NB4 function is looking at how the frequency of noise from a gearbox changes as a damaged tooth passes the sensor. I understand the concept, but I don't understand what the math is actually computing...
The Hilbert transform is an integral transform (much like Laplace and Fourier) as defined at mathworld here.Mathwolrd Link
The Mathematical definition there really doesn't give much insight into the application of the HT in the example you quote. If however you look at the table of Hilbert Transforms at the link you'll notice that sin(.) and cos(.) are transform pairs, this is basically the key to what the HT is doing in your example.
Essentially for narrow band signals (and possibly others - can't remember the full details) the Hilbert Transform is much the same as a 90 degree phase shift on every frequency component. This has significant application in the field of "envelope detection" as a tractable method of obtaining the approx instantaneous envelope of an oscillatory signal.
Imagine for example that you're looking at an amplitude modulated sine wave and you wish to process it in some way so as to preserve only the modulating function (that is the envelope) and throw away oscillations. If you can generate a quadrature signal of the same modulation (envelope) then you can easily generate the instantaneous envelope (A(t)) from :
A(t) cos^2(.) + A(t) sin^2(.) = A(t).
So in a nut shell that's what the Hilbert transform is doing in your quoted application. :)
Ah. That makes sense.
Thanks uart!
  • · Replies 20 ·
