Can a Laser Be Amplified by Plasma?
  • Context: Graduate
  • Thread starter Thread starter Chronothread
    Laser Plasma
The discussion revolves around the concept of whether a laser can be amplified by passing through plasma, particularly in the context of a proposed "Giant Solar Laser." Participants explore the mechanisms of lasing in plasma, the differences between various types of plasma, and the theoretical implications of such amplification.
  • Some participants question the feasibility of using plasma for lasing, suggesting that plasma, consisting of free ions and electrons, may not function similarly to gas lasers that rely on metastable states.
  • Others argue that plasma can be used for lasing if the ions are not fully stripped, allowing for bound electrons to exist in metastable states, as seen in laboratory x-ray lasers.
  • A participant mentions free electron lasers (FELs) as a different approach but expresses skepticism about their applicability in the context of unstable plasma.
  • There is a discussion about the potential for nuclear excitation when photons interact with nuclei, with some participants seeking clarification on the processes involved.
  • Some participants reference historical concepts of plasma-based x-ray lasers from the Reagan-era SDI program, noting their relevance to the discussion.
  • Concerns are raised about the energy requirements for exciting nuclei with photons, particularly in relation to gamma-ray interactions.
Participants express differing views on the viability of amplifying lasers through plasma, with no consensus reached on the mechanisms or theoretical foundations involved. The discussion remains unresolved regarding the specifics of how plasma could facilitate laser amplification.
Participants highlight the distinction between partially ionized and fully ionized plasmas, as well as the differences between various types of lasers and their operational principles. There is also mention of unresolved questions regarding photon interactions with nuclei and the conditions necessary for nuclear excitation.
Chronothread
Recently I read the thread "Giant Solar Laser" in the General Astronomy Forums. The author, Ruslan_Sharipov, writes
one can shoot a laser pulse from a satellite expecting that it will be amplified when passing through the near-solar plasma
I was just wondering if someone could explain specifically how a laser will be amplified when passing through plasma. Thank you for your time.
I am not sure that a plasma - free ions and electrons - can be using in a lasing process like that in gas lasers. Lasers utilize metastable states in which an electron 'drops' to lower energy level when 'stimulated' by a photon of the characteristic energy difference. That is why lasers are monochromatic, more or less.
I would like to see the theory and the wavelengths proposed.
Hopefull Mr. Sharipov will submit his theory to Independent Research.
https://www.physicsforums.com/forumdisplay.php?f=146
Plasmas can be used for lasing, e.g. http://laserstars.org/history/plasma.html ,
but that is not the same as a solar plasma.
One would have to distinguished between partially ionized gas and highly ionized.
Typically I think of gas lasers as various combinations of He-Ne-Ar-Kr-Xe-F and CO2, as opposed to solar plasmas which are mostly H and He.
Thank you.
It can as long as the ions aren't fully stripped, meaning the ions have bound electrons that can in the right circumstances be in metastable states. This is how laboratory x-ray lasers are made, and they work the same way as conventional lasers except they're typically amplified spontaneous emission rather than resonator cavities. A lot of work went into their development in the '80s and '90s, and a small x-ray laser research field still exists, though the hoped-for applications for the most part didn't pan out.
Free electron lasers are rather different beasts, perhaps this is what he had in mind - http://en.wikipedia.org/wiki/Free_electron_laser. This requires a relativistic electron beam.
I have no idea what he's thinking about based on what he posted.
Edit: I just saw the related locked thread below and realized the idea appears not to be founded in science... Also, Astronuc, the Reagan-era SDI laser concepts were plasma-based x-ray lasers, not chemical lasers, though this can't have anything to do with the poster's ideas either.
Er... FEL is totally out of the question here. The requirement for the electron beam (i.e. ultra low emittance and low energy spread) would never be fulfilled by a plasma that is highly unstable. Even the high gradient achived in plasma accelerators have not touted that technique as being able to be used to generate FELs.
Zz.
A bit of topic but this 'stripped' case is the one in which I am interested. I am well versed in the electron stimulation by quanta, but lack even the vocabulary to go googling for what happens when a photon hits a nucleus - ion w/ no electrons. I assume there must still be quantum energy states for nuclei? Are there there the equivalent absorption / emission processes? Id appreciate some pointers for where to begin, or even the appropriate terms.
mheslep
mheslep
There have been proposals for gamma-ray lasers based on excited nuclear isomers, this link talks a bit about the idea and provides other links you can chase down if you're interested: http://en.wikipedia.org/wiki/Gamma_ray_laser. I think one major problem is gathering enough material to see a significant effect. But this can't have had anything to do with the poster's solar laser idea either...
Many thanks
The solar plasma does not consist of fully stripped ions only. Remember the discovery of helium or read the following link: http://www-solar.mcs.st-and.ac.uk/~clare/Lockyer/helium.html".
we all know that plasma cis a big source of radiations.i.e xrays,ions,electrons etc.i want to know tat how these xrays are emitted from plasma.please tell me thanks
I know. One of my professors in grad school was involved with nuclear-pumped lasers, including X-imer (Excimer), and other SDI concepts. Interesting stuff. :biggrin:
My research interest was high power density systems capable both steady-state and transient power capability. It was dual-use technology, and I was interested in propulsion rather than weapons applications.
Certainly. In my original response, I was primarily thinking of solar plasma, as opposed optically-pumped gas (He, Ne, Ar, . . .) lasers.
I was hoping there would be a better description of the proposed "Giant Solar Laser".
Certainly poly-electronic atoms can be partially ionized, i.e. lose one or more electrons and still have bound electrons.
A proton is a hydrogen ion - there is only one electron. One could have H2+. However, in general, hydrogen plasmas are largely protons, electrons and some concentration of neutrals. Li and on up can certainly have poly-electronic positive ions.
I was only interested in nuclear excitation - no bound electrons, as in a plasma. From up thread, my question was what happens when a proton/nucleus is hit by a photon. The answer seems to be an excited nucleus or nuclear isomer can result if the photon is in the gamma ray range. If the photon is of lower energy then I'm not sure what happens. At much lower wavelengths/energies then I fall back on a simple E-M wave interaction w/ the nucleus where the E & M parts of the wave would oscillate the charged particle and simply push it around as it passes, but it is not a nuclear excitement.
Well think about the energy of a gamma photon required to excite a nucleus - it has to come from a nuclear source in the first place or one heck of an EM interaction.
The cross-section for photon-electron interaction is much greater than for a photon-nuclear interaction, and one is more likely to get pair-production for E(gamma) > 1.022 MeV, although there are a number of isotopes for which photo-neutron emission is a possible interaction.
At lower gamma/X-ray energies, Compton and photoelectric effects dominate.
Yes I see that from http://en.wikipedia.org/wiki/Image:In115small.jpg" that only very large energies are allowed, apparently only at multiples of 1/2 spin? Though, I don't anything about why 1/2 spin is a fundamental nuclear quantity. Some Standard Model concept I suppose.
Yes I see in Boyd and Sanderson's text that the ponderomotive force works by pushing electrons about which in turn creates an electrostatic gradient that pulls the +ions along.
Just a guess, MIT? :smile:
  • · Replies 16 ·
