Calculating Induced EMF in a 5.56m Steel Beam Dropped from 3.97m
The problem involves calculating the induced electromotive force (emf) in a steel beam that is dropped from a specific height, while considering the influence of the Earth's magnetic field and gravitational acceleration.
  • Participants discuss the relationship between gravity and the velocity of the beam just before impact, questioning how to derive velocity without a given time period. There is mention of using equations related to induced emf and kinematic equations.
The discussion is active, with participants exploring different aspects of the problem, including the role of gravity and the application of kinematic equations. Some guidance has been offered regarding the use of specific equations to find the necessary velocity.
Participants note the absence of a time variable in the problem, which adds complexity to determining the beam's velocity just before impact.
Aerospace
A 5.56m long steel beam is accidentally dropped by a construction crane from a height of 3.97m. The horizontal component of the Earth's magnetic field over the region is 28.4e-6T. Acceleration of gravity is 9.8 m/s^2.
What is the induced emf in the beam just before impact with the Earth, assuming its long dimension remains in a horizontal plane, oriented perpendicularly to the horizontal component of the Earth's magnetic field?
I sort of have an idea how to begin but the whole gravity thing is confusing me. Any help?
I think that gravity only plays a role since you will want to know how fast the beam is traveling through the magnetic field just before it hits the ground.
YUP! That's what I was thinking too. One of the equations for induced emf is E=Blv but how do I get the velocity from the gravity because i am not given a time period. It's probably something just basic...but I can't seem to grasp on it at this moment.
Just use the kinematic equations. You are given the height it is falling from, and you know how fast it accelerates due to gravity.
Without time, use [tex]v_{f}^2=v_{i}^2+2a(y_{f}-y_{i})[/tex]
  • · Replies 41 ·
9K
