New Reply
Free Particle Action
Share Thread Thread Tools
Jun21-07, 12:31 PM   #1
I've recently started Feynman & Gibbs. I was sure exercises will be fun, but i can't enjoy myself when i fail solving the first one! Exercise 1-1 says: show that free particle action is
[tex]\frac{m}{2} \frac{x_b^2 - x_a^2}{t_b-t_a}[/tex]
I tried finding anti-derivative of [itex]\dot x^2[/itex], ended up with [itex]x\dot x - \int x d(\dot x)[/itex] via integration by parts. Couldn't do much about the integral. Of course, I know the solution, and can show it using Euler-Lagrange equations, [itex]x=vt[/itex] where [itex]v[/itex] is a constant (taking [itex]x_0=0[/itex]). I can "solve" the question by substituting [itex]x[/itex] in the action integral
[tex]S = \int_{t_a}^{t_b} \frac{m}{2}v^2 dt[/tex]
but i suppose this counts as cheating --kinda solving backwards.
Any ideas on how this kind of stuff can be solved?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jun22-07, 12:40 AM   #2
It's not cheating. The action have different values on different paths. The principle of least action claims that the actual path will extremize the action.
They want you to find the path that extremizes the action by using the usual Euler-Lagrange equations. You know the answer should be motion of constant velocity, x = xa + vt, where v = const = (xb-xa)/(tb-ta). Then you plug that in and evaluate the action on that path.
Jun22-07, 10:50 AM   #3
Quote by gulsen View Post
Shouldn't it be:
[tex]\frac{m}{2} \frac{(x_b - x_a)^2}{t_b-t_a}[/tex]
The exercise asks you to find the action S. How S is defined? It's defined as
[tex]S = \int_{t_a}^{t_b} \L dt[/tex]
where L = T - V; T = kinetic energy and V = potential energy;
In this case, V = 0 and T = [tex] \frac{m}{2}v^2 [/tex] and to write kinetic energy you surely don't need Eulero-Lagrange equations, I hope, kinetic energy is defined in that way!
So:
Where is the problem? Always start from definitions.
Feb17-11, 05:06 PM   #4
Recognitions:
Homework Helper Homework Help
This looks wrong but the equation of motion here is [tex]\ddot{x}=0[/tex], so:
[tex]
S=\frac{m}{2}\int_{t_{a}}^{t_{b}}\dot{x}^{2}dt=\left[ x\dot{x}\right]_{t_{a}}^{t_{b}}-\int_{t_{a}}^{t_{b}}x\ddot{x}dt
[/tex]
Now in second integral is zero by the equation of motion. Not too sure where to go from here.
Feb17-11, 10:18 PM   #5
Quote by hunt_mat View Post
[tex]
[/tex]
Remember that [tex]\dot{x} [/tex] is the same at the initial time and final time, since [tex]\ddot{x}=0 [/tex].
So you get [tex]\left[ x\dot{x}\right]_{t_{a}}^{t_{b}}=\dot{x}(x_b-x_a)=\frac{(x_b-x_a)^2}{t_b-t_a} [/tex]
So you can check that the derivative of the action:
[tex]S=\frac{m}{2}\frac{(x_b-x_a)^2}{t_b-t_a} [/tex]
with respect to x_b equals momentum, and with respect to time equals negative energy (which in this case is just kinetic).
New Reply
Thread Tools
Similar Threads for: Free Particle Action
Thread Forum Replies
where is action free? Linear & Abstract Algebra 0
Poincare invariant action of a point particle Classical Physics 5
Poincaré invariant action of a point particle Advanced Physics Homework 4
Action for a point particle with world line SUSY Beyond the Standard Model 0
