Displacement, time and average velocity
Therefore, the average velocity is 0 km/hr.In summary, a shearwater was taken from its nest and released 5150km away, finding its way back to its nest 12.5 days later. The bird's average velocity for the return flight was 17.2 km/hr. For the entire episode, the average velocity was 0 km/hr.
Equilibrium
82
In an experiment, a shearwater (seabird) was taken from its nest, flown 5150km away, and released. It found its way back to its nest 12.5 days after it was released. If we place the origin at the nest and extend the +x-axis to the release point what was the bird's average velocity for a.) The return flight? b.) the whole episode, from leaving the nest to returning?
[tex] V_{ave} = \frac{\delta{d}}{\delta{t}} [/tex]
t = 12.5 days (24 hrs/ 1day) = 300hr
a.) 5150 km / 300hr = 17.2 km /hr
b.) I think the answer is zero
Yes, that is correct. Since the problem asked for "velocity" rather than "speed", to find the average velocity for the entire trip, you use the same starting and ending point- the net distance is 0.
, as the displacement is zero since the bird returned to its original position. However, if we consider the displacement as the total distance traveled (5150km + 5150km = 10300km), then the average velocity would be 34.3 km/hr. It is important to clarify the definition of displacement in this scenario.
What is displacement?
Displacement is a measure of the change in an object's position from its starting point to its ending point. It is a vector quantity, meaning it has both magnitude and direction.
How is displacement different from distance?
Distance is a measure of the total length of the path an object has traveled, while displacement is a measure of the shortest distance from the starting point to the ending point. This means that displacement can be equal to, less than, or greater than the distance traveled.
What is time and how is it related to displacement?
Time is a measure of the duration of an event or the interval between two events. In the context of displacement, time is used to calculate average velocity, which is the displacement divided by the time interval.
What is average velocity?
Average velocity is the rate of change of an object's displacement over a period of time. It is calculated by dividing the displacement by the time interval. It is a vector quantity and has both magnitude and direction.
How is average velocity different from instantaneous velocity?
Average velocity is calculated over a specific time interval, while instantaneous velocity is the velocity of an object at a specific moment in time. Average velocity gives a general idea of an object's overall motion, while instantaneous velocity gives information about an object's motion at a specific point in time.
20K
