Why Does Earth Experience Only Two Extreme Distances from the Sun in Its Orbit?
  • Context: Graduate
  • Thread starter Thread starter deda
    Sun The sun
The Earth experiences two extreme distances from the Sun, known as Apogee and Perigee, due to the elliptical nature of its orbit. This orbit is defined by the gravitational forces acting between the Earth and the Sun, with the Sun located at one focus of the ellipse. The discussion argues against the notion of having four extreme distances, asserting that the balance of forces and the center of mass dictate a single elliptical trajectory. The analysis highlights that any additional force applied to an object in this system alters the perceived distances but ultimately conforms to the elliptical model established by Kepler's laws.
  • Understanding of Kepler's laws of planetary motion
  • Basic knowledge of gravitational forces and center of mass
  • Familiarity with elliptical geometry
  • Concept of force balance in physics
  • Study Kepler's laws in detail, focusing on elliptical orbits
  • Explore gravitational force calculations and their implications on orbital mechanics
  • Investigate the concept of center of mass in multi-body systems
  • Examine the effects of additional forces on trajectories in physics
Astronomers, physics students, and anyone interested in understanding the dynamics of planetary orbits and gravitational interactions.
deda
Currently the Earth has two extreme distances from the sun: Apogee and Perigee (one minimal, one maximal). Shouldn’t there be four extreme distances between the sun and the earth: pair of opposite minimums and pair of opposite maximums? Both the sun and the Earth have mass. So, there must be center of mass between them. I find the center of force at the same position. The system can be balanced only if that center is immovable. Statically, the condition for balance makes the ratio of their forces inverse the ratio of their distances from that center. The center also must be between them. The angle of rotation must be same for both and its makes the two oscillate around same center. Assume their trajectories are perfect circles. Now let's double the force at one point. It will be same as if we added only half of the force at that side and opposite half on the other side. What matters is that we added force only in one direction. Its component with normal direction remained the same. So the trajectory must have pair of opposite minimal and maximal extremes i.e. the trajectory must be an ellipse with same center as the center of force.
The way Kepler solves the trajectory using Newton’s laws makes the forces strangely variable, which I find hard to explain because of absence of balance. Here is an example proving that Kepler’s solution doesn’t hold: Dig a tunnel through the Earth all the way from the North Pole to the South Pole. Drop one object from distance H. The extreme distance on the other side will be -H from the center of earth. Now repeat the whole thing again but this time input additional force at the drop point (you would prefer me to say drop it with initial speed). The extreme distance on south will be bigger than the initial one north but on return the extreme distance north will equalize with the south one. It’ll only seem as if you’ve dropped it from bigger distance without the additional force input. Point made.
The Earth's orbit (neglecting miniscule corrections due to the moon and other planets) is an ellipse with the sun at one focus. The ends of the major axis of this ellipse are the minimum and maximum respectively.
  • · Replies 23 ·
