How Much Heat To Turn Water To Steam?
In summary, to convert 120g of water from a liquid to steam, it requires a heat addition of 120*539 = 64800 cal, and then the latent heat of vaporization of water, 540 cal/g.
mike2007
46
How much heat must be added to 120g of water at an initial temperature of 60C to
heat it to the boiling point?
completely convert the 100C water to steam?
Specific heat capacity of water = 1.0cal/g-C
It would take 120*1 to raise 120g of water up to 1C
difference in temperature = 100C - 60C = 40C
It would then take 120*40 to raise it to the boiling point
120*40 = 4800cal
specific heat of steam is 0.48 cal/g-C but what it the temperature of steam?
Temperature of steam at 1 atm (0.101325 MPa, or 14.7 psia) is 100°C (212°F). Steam represents a phase change.
Steam however can be superheated, but that would be in a vessel with higher steam pressure, otherwise the steam expands and cools.
Remember, the problem increasing the water temperature, then transforming liquid water at 100°C to steam (water vapor) at 100°C.
See
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/phase2.html#c3
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/phase.html
But what do i use for the calculation of water to steam. Doesnt the system have to have some amount of heat added to convert it to steam.
You need the latent heat of vapourization of water for the last part of the calculation, not the specific heat of steam ;)
Look at the first link I provided.
The energy required to change a gram of a liquid into the gaseous state at the boiling point is called the "heat of vaporization". This energy breaks down the intermolecular attractive forces, and also must provide the energy necessary to expand the gas.
Converting liquid water to steam at 100°C (0.101325 MPa) requires a heat addition of 539 cal/g (2260 J/gm).
The latent heat for boiling is 540 cal/g. That means that 1g requires 540 cal of heat to steam
Thus, 120g requires 120 x 540 = 64800 cal to steam
Correct.
And then add the two heat requirements.
What is the boiling point of water?
The boiling point of water is 100 degrees Celsius or 212 degrees Fahrenheit at sea level. This is the temperature at which water changes from a liquid to a gas, or steam.
How much heat is needed to turn water to steam?
The amount of heat needed to turn water to steam depends on the initial temperature and volume of the water, as well as the atmospheric pressure. However, on average, it takes about 2260 joules of energy to convert 1 gram of water at 100 degrees Celsius to steam at the same temperature.
Why does water turn to steam when heated?
When water is heated, the molecules gain energy and start moving faster. As the temperature reaches the boiling point, the molecules have enough energy to overcome the intermolecular forces holding them together, and the water turns into steam.
Does water always turn to steam at 100 degrees Celsius?
No, the boiling point of water can vary depending on the atmospheric pressure. For example, at higher altitudes where the atmospheric pressure is lower, water will boil at a lower temperature. At sea level, however, water will always boil at 100 degrees Celsius.
Can you turn water to steam without heating it?
Yes, it is possible to turn water to steam without heating it through a process called sublimation. This occurs when the surrounding air is very dry and the water molecules gain enough energy to directly transition from a solid (ice) to a gas (steam) without going through the liquid phase.
