| Thread Closed |
Energy conservation |
Share Thread | Thread Tools |
| Jul7-07, 03:10 AM | #35 |
Energy conservationlet me ask it in a simple manner? consider you are at rest or in uniform motion. A rocket is moving at uniform velocity with respect to you. Another rocket passed you with an acceleration. (consider you don't know,wheather a thrust is applied on the rockets during its journey past you-you have been assingned to find out the force acting on these rockets). What will be the force(net) acting on these rockets? Do you use f = m*a in the case of second rocket? or do you say a force was acting on that rocket in past. Please explain me how you will confirm,the acceleration was due to some action in past or it is attained during it was passing you. regarding golf club really accelerates quickly.it depends on how hard you hit it.forgetting all other forces,we can say ,acceleration takes a time equal to the time required for ball to reach its final velocity from zero velocity.it never can be zero. |
| Jul7-07, 03:29 AM | #36 |
Recognitions:
I'll ingore the fact that the accelerating rocket is using fuel for it's thrust and therfore it's mass is decreasing over time as it accelerates. |
| Jul7-07, 05:33 AM | #37 |
If you can use the equation force equals mass times acceleration(without knowing the time of application of thrust(force) ,it is equaly valid in the case of ball in the previous example. So if you really mean what you say,you are confirming that a force is acting on an accelerating body,irrespective of the time of application of force(if it is accelerating). you see the ball coming accelerating.[you din't see wheather it was hit by a club or thrown by somebody] .But you see the ball is accelerating,so of course as in the case of the second rocket,there should be a force acting on ball or not? if still you say no ,there is no force acting (the force was acted only at the instant of club hit the ball).then you are challenging the equation or you are going to put some conditions(ie,force can be calculated only if acceleration is very quick or acceleration will be considered only at the instance of the application of force etc.etc) |
| Jul7-07, 06:27 AM | #38 |
Mentor
The freebody diagram of the ball would show: Before the club hits: gravity acting down; normal force acting up. As the club hits: gravity acting down; huge impulsive force of the club acting at some angle. After the club loses contact: gravity acting down; air resistance acting in the opposite direction to its motion. Again, you seem to think that by examining the speed of something you can figure out its acceleration or deduce that some force is acting. Again, it's quite simple: Is the velocity changing now? If so, then there is a force acting on it now. If the velocity is steady now, then there's no net force acting on it now. Of course, if you wish to measure the change in velocity, you'll need to make observations over some time interval. |
| Jul7-07, 08:27 AM | #39 |
yes .first case resultant is zero.so no motion-agreed. second case,of course resultant is in the direction of motion of club,fine the ball will move in that direction. But in the third case ,you can see the direction of resultant is opposite.so where should the ball move.? in any freebody diagram,the object should move in the direction and with a magnitude equal to the resultant of all forces. So don't you feel something is missing?At least don't you think the motion of ball has to be considered as a force in that direction? |
| Jul7-07, 09:34 AM | #40 |
Mentor
I urge you to study Newton's laws of motion. Start here: Newton's Laws and the causes of motion |
| Jul7-07, 12:26 PM | #41 |
Are you implying here that the ball is accelerating in the forward direction through the air after it leaves the club? That seems to me what you're trying to say, and it's completely wrong. Once the ball leaves the club, it has no forces acting on it besides air resistance and gravity. So if I'm hanging out in the air and see this ball fly past me, I would see that it has a substantial velocity in the forward direction and a small acceleration in the backward direction. In other words, the ball would be slowing down, not speeding up. I would not see the ball going faster and faster as it approaches me. I would see it going slower and slower. The only conclusion that I could correctly draw from this is that the net force on the ball is in the backward direction. This is the correct conclusion. Consider the case of a car. When a car is moving forward at a constant velocity, all of the forces acting on the car - the engine's thrust in the forward direction, rolling friction and air resistance in the backward direction, gravity in the downward direction, normal force in the upward direction - are balanced. Say this car is moving at 90mph North. What happens when the driver of this car takes his foot off the gas and applies the brakes? Now what would the free-body diagram for this car look like? All forces would be directed South, right? But does this car immediately stop and begin moving South? No, it begins to decelerate. If, say, the brakes were applied for 2 seconds, perhaps the car would slow down to 70mph, but it would still be moving North, even though, for a certain time interval, all of the forces on the car were pushing South. This is the same as the case of the ball. When the ball is in the air, say it is moving at 150mph North. All of the forces on the ball will be acting in the South direction, but this does not mean that the ball moves South. It simply accelerates to the South. It accelerates in the opposite direction of the its motion; in other words, it slows down. It does not immediately stop and turn around. This is directly analogous to the car situation. What is it that you're not understanding here? Maybe it's the definition and behavior of a force? A force does not cause motion, it causes acceleration. Don't confuse the two. |
| Jul7-07, 12:45 PM | #42 |
Alright... enough is enough.
I'm staying 'way the hell back from any of that math stuff. Even without it, it's bloody obvious that a relatively moving body has kinetic energy. If you don't believe it, try standing in front of a bullet. As for the cause of inertia, it's just the reluctance of mass to change its current state of motion. (And the last that I read, we don't yet know what 'causes' mass.) edit: Wow... a tonne of responses in there while I was composing this. I'd love to read them all, but since I'm at work, I'm too drunk to follow them. |
| Jul7-07, 02:11 PM | #43 |
newTonn,
I'm going to add some points to these other good posts. You have a confused notion about force and inertia which I can't quite follow from your posts. Inertia is purely the conservation of momentum. Kinetic momentum (mass times velocity) is conserved in the absence of forces. Kinetic energy (approximately half mass times squared velocity) is conserved in the absence of forces. A force applied to an object changes its kinetic energy (Newtonian scalar) in proportion to how far the object travels in the direction of the force, and changes its kinetic momentum (Newtonian vector) in proportion to how long it is applied. When considering "instantaneous" forces we are ignoring the time and distance element and the magnitude of the force and only looking at these product components of change in momentum and change in kinetic energy. [itex]\Delta[/itex] here means "change in", [itex]T[/itex] means kinetic energy and [itex]\mathbf{P}[/itex] means (vector) momentum. [tex] \Delta KE = \mathbf{F}\cdot \Delta \mathbf{X}[/tex] (force constant throughout the displacement) [tex]\Delta \mathbf{P} = \mathbf{F}\Delta t[/tex] Once you understand momentum and energy and how forces change these, then consider acceleration as change in velocity and thus how forces accelerate by changing the momentum which is proportional to the velocity. Finally let me say that you are trying to analyze scenarios verbally without breaking down and doing the vector math. You really really really need to dig through the mathematics to see how everything fits together. Start with two massive balls colliding in two scenarios: bouncing off each other (elastic collision where energy is conserved) and hitting and sticking to each other (inelastic collision where energy will not be conserved). Try first one dimensional and then two dimensional scenarios. In fact you should work out billiard ball collisions on the table, identifying where the cue must hit the object ball to make a shot, and then where the cue ball ends up hitting the bank (to see if you will scratch). This is a good practical exercise and you can test your calculations at the nearest pool hall. To figure the angles assume the force between the balls is perpendicular to their surface at the point of contact (i.e. ignore ball-ball friction). Remember that you can hypothesize and deduce all day but none of this has scientific meaning until you test your hypotheses with empirical experiments. The pool shot exercises will be both instructive and fun. |
| Jul7-07, 02:21 PM | #44 |
Oh, sure... go and get math involved again...
![]() Nice post, James.
| Jul7-07, 06:54 PM | #45 |
I think the major issue is Newtonn is picturing the golfball still accelerating FORWARD after it leaves the club. Which it isnt.
But he IS right in that , the free body diagram, the forces are not net zero. There is a force that is due to air resistance, this pushes say, to the left if the ball was hit to the right. There is a force downward due to gravity. So if you took a static picture of the ball, you would say that it would move down and left, correct? BUT the ball had an initial velocity, so that velocity WILL slow down. But remember that wind resistance is a FUNCTION of its RIGHTWARD VELOCITY. So once it slwos down to zero to the right, it wont keep going left. Theres no more force on it leftward. As for the gravity, since it was hit UP, the gravity SLOWS it first to Zero (its peak) then it DOES move DOWN. And it would keep accelerating if it could never hit the earth. As for your rocket example. The second rocket that is ACCELERATING past you MUST have a current thrust. Once the thrust stops, the acceleration stops. They are the same thing. You cannot thrust some rocket, stop the burners/jets, and expect it to continue accelerating. It stops accelerating the INSTANT that thrust stops, and continues at its current velocity. Please respond with your questions. So, remember, that "acceleration" can mean going from 100 m/s to 50 m/s. Slowing is acceleration too. Don't forget that. Accel is the change in speed, in any direction. So it has to change its current velocity. |
| Jul7-07, 11:44 PM | #46 |
still i cannot digest,how a velocity (and thus an acceleration)is acquired without displacement of ball? |
| Jul7-07, 11:51 PM | #47 |
I get the sense that you are more interested in being right than in being correct. |
| Jul7-07, 11:54 PM | #48 |
The ball attains its final velocity from same position and same instance. how can it be possible? forget about all other forces exept that from club.Does the ball require a time interval to reach its final velocity?and is a displacement necessary ,to acquire a velocity? |
| Jul7-07, 11:57 PM | #49 |
Not at all,i would like to be corrected in a correct manner. |
| Jul8-07, 12:22 AM | #50 |
I don't know what you mean by the first sentence at all, but as for the other parts of your post: Yes, the ball requires a time interval to reach its final velocity, and yes there is a displacement necessary to acquire this velocity. The ball is in contact with the club for a small but definite interval of time. It appears to us that the ball is only in contact with the club instantaneously, but in reality (as was shown by a video posted earlier), the ball is in contact with the club for a few hundredths of a second. There is no conflict with the laws of physics here. The ball is accelerated very quickly over a short distance and a short time period. |
| Jul8-07, 03:09 AM | #51 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Energy conservation
| conservation of momentum vs conservation of kinetic energy | Introductory Physics Homework | 18 | ||
| Simulatenous Conservation of Momentum and Conservation of Energy | Engineering Systems & Design | 9 | ||
| Conservation of energy or conservation of momentum | Introductory Physics Homework | 2 | ||
| Transformation of Kinetic and Gravitational Potential Energy:Conservation of Energy. | Introductory Physics Homework | 9 | ||
| Conservation of momentum (with conservation of energy) | Introductory Physics Homework | 1 | ||
